EBC? what EBC?
EBC? what EBC?
Postby Yoshi » Thu Sep 23, 2010 12:09 pm
http://www.e30tech.com/forum/showthread.php?t=54103
I'm probably getting my MS3 to do boost control, but this seems to be a good solution all around. I could just wait for my MS3 but I'm not even sure it'll be a winter project anymore lol. $50ish worth of parts for full control is pretty nice. thoughts?
Re: EBC? what EBC?
Postby pr0craztinazn » Thu Sep 23, 2010 12:42 pm
Theory is sound....
joecrotch
Re: EBC? what EBC?
Postby joecrotch » Thu Sep 23, 2010 9:23 pm
the saab scene has been doing this for many years! we in fact have like 5 manufacters now that make these. this is the best one though.
http://smartperformance.net/index.php?cPath=21
Re: EBC? what EBC?
Postby Yoshi » Thu Sep 23, 2010 9:30 pm
that looks nice. but it doesn't seem to do everything this one does. I need to find my pressure regulator.
joecrotch
Re: EBC? what EBC?
Postby joecrotch » Thu Sep 23, 2010 9:47 pm
so basicly this is what you need. just one that adjust at less psi. the arrow side to the wastegate and the threaded side to the pressure regulator.
http://www.amazon.com/dp/B000936L24/ref ... B000936L24
Re: EBC? what EBC?
Postby Yoshi » Thu Sep 23, 2010 9:53 pm
Nah man. read the article. It's got boost creep protection (quicker spool), pressure release between shifts, and boost control.
joecrotch
Re: EBC? what EBC?
Postby joecrotch » Thu Sep 23, 2010 9:55 pm
from what i read all it is, is a pressure relief valve. when oost signal from mbc reaches set psi it allows tha signal to pass through to the wastegate. (fancy name for pressure relief valve)
Re: EBC? what EBC?
Postby Yoshi » Thu Sep 23, 2010 9:58 pm
yea. It's a whole thing tho. I can make one for $50. The site you posted has it for $75 and doesn't have all of the other parts to it.
joecrotch
Re: EBC? what EBC?
Postby joecrotch » Thu Sep 23, 2010 10:11 pm
the sight I posted actually is a mbc+a its whats called a anticipator which is pretty much the oppisite of the one your trying to do but it makes for very precise boost adjustments. I can adjust my Saabs boost in .5 psi incriments. (spelling I know, I'm tired) but can you imagine all three together!!!! insane adjustability!!
MBC - for max boost adjustments
+a -for elimination of boost creep and precise adjustability + spool time
EBC - for elimination of wastegate creep + spool time
hhhm its a thought!
Re: EBC? what EBC?
Postby M20_fever » Fri Sep 24, 2010 12:54 am
if I ever get my MS from Mitch it will have full boost control, flat shift rev limiter, and 2 step rev limiter. I really hope he comes through...
Re: EBC? what EBC?
Postby Yoshi » Fri Sep 24, 2010 1:06 am
kewl
Re: EBC? what EBC?
Postby M20_fever » Fri Sep 24, 2010 1:29 am
I imagine MS3 will have some new goodies like that, no?
Re: EBC? what EBC?
Postby Yoshi » Fri Sep 24, 2010 1:41 am
Yea but that might a ways away for me. This is a $50 temp fix that works really well. Not bad IMO.
Re: EBC? what EBC?
Postby M20_fever » Fri Sep 24, 2010 2:09 am
not bad at all.
