MS3 comprehensive experience thread
Re: MS3 comprehensive experience thread
Post by Yoshi » Mon Nov 15, 2010 12:50 am
It's a thread tho. MT is created BY the same creators as the MS. I can't imagine they wouldn't make software for their own hardware. Tuner studio is 3rd party. MT isn't. Wherever you get the firmware for your MS3x will have the ini for MT.
Last ditch effort is a phone call or email to DIYautotune lol.
Post by M20_fever » Mon Nov 15, 2010 2:32 am
sigh, ok I've been working through the MS3 walkthrough I found on DIY, but now TS keeps throwing an error that says: "Warning!! Communication Established! However, there is a configuration error with your firmware. Check to make sure your MS3 firmware is correctly loaded. Going offline."
The only way to get rid of the error is to turn off the stim, but it comes back as soon as I turn the stim back on. I just loaded the current firmware before starting to calibrate the sensors...
edit: I reloaded the firmware again, seems to be working so far.
Post by M20_fever » Mon Nov 15, 2010 12:28 pm
Hey Yosh, take a look at my Ignition settings;
What should my trigger angle/offset(deg) be? Do the rest of those settings look right?
Post by Yoshi » Mon Nov 15, 2010 1:13 pm
Base looks good. I forget about skip pulses (or remember it at all). Your cranking and dwell settings will depend on those coil you got. 6 dwell for cranking seems kind of long to me.
Post by M20_fever » Mon Nov 15, 2010 8:10 pm
can you post your setting, just curious. So I don't need to put anything for trigger angle?
Post by Yoshi » Mon Nov 15, 2010 8:17 pm
<?xml version="1.0" encoding="ISO-8859-1"?>
<msq xmlns="http://www.msefi.com/:msq">
<bibliography author="MegaTune 2.25 p3" writeDate="2009-05-21T10:32:25-04:00" />
<versionInfo fileFormat="4.0" nPages="9" signature="MS1/Extra format 029y3 *********" />
<page number="0" size="189">
<constant name="algorithm1">"Speed Density"</constant>
<constant name="alternate1">"Alternating"</constant>
<constant name="baroCorr1">"Off"</constant>
<constant name="battFac1" units="ms/v">0.20</constant>
<constant name="cltType1">"GM"</constant>
<constant name="divider1">3</constant>
<constant name="egoCount1">31</constant>
<constant name="egoDelta1" units="%">1</constant>
<constant name="egoIgnCount">"mSec"</constant>
<constant name="egoLimit1" units="%">20</constant>
<constant name="egoRPM1" units="RPM">1300</constant>
<constant name="egoSwitch1" units="v">2.509</constant>
<constant name="egoTemp1" units="C">-12</constant>
<constant name="egoType1">"Wide band"</constant>
<constant name="engineType1">"Even fire"</constant>
<constant name="fastIdleT1" units="C">-40.0</constant>
<constant name="injOpen1" units="ms">1.0</constant>
<constant name="injPwmP1" units="%">100</constant>
<constant name="injPwmT1" units="ms">25.5</constant>
<constant name="mapBins1" rows="12" units="kPa">
20
30
40
55
70
85
100
120
140
180
200
220
</constant>
<constant name="mapSensor1">"1"</constant>
<constant name="mapType1">"250 kPa"</constant>
<constant name="matType1">"GM"</constant>
<constant name="nCylinders1">"6"</constant>
<constant name="nInjectors1">"6"</constant>
<constant name="reqFuel1" units="ms">7.1</constant>
<constant name="rpmBins1" rows="12" units="RPM">
600
1200
2000
2400
2800
3200
3600
4000
4400
5200
6000
6800
</constant>
<constant name="rpmk1">2000</constant>
<constant name="twoStroke1">"Four-stroke"</constant>
<constant cols="12" name="veBins1" rows="12" units="%">
39 42 55 63 59 56 52 45 39 37 46 50
38 44 51 58 51 41 41 41 44 44 53 60
40 52 51 53 52 35 43 44 47 49 55 69
69 68 57 61 58 49 55 56 64 65 72 75
69 74 66 69 67 68 60 64 67 71 72 75
65 77 72 69 68 67 68 70 76 79 74 80
63 78 79 73 73 71 72 73 84 82 83 84
65 72 71 82 82 73 79 80 88 89 88 89
75 77 79 72 88 84 86 96 95 101 99 97
75 70 81 101 101 102 103 105 109 111 108 112
75 90 90 100 104 115 121 125 126 126 113 115
80 110 110 110 111 114 122 126 128 125 115 90
</constant>
</page>
<page number="1" size="189">
<constant name="TwoLambda">"None*^(DT)"</constant>
<constant name="algorithm2">"Speed Density"</constant>
<constant name="alternate2">"Simultaneous"</constant>
<constant name="baroCorr2">"Off"</constant>
<constant name="battFac2" units="ms/v">0.20</constant>
<constant name="cltType2">"GM"</constant>
<constant name="divider2">4</constant>
<constant name="egoDelta2" units="%">1</constant>
<constant name="egoLimit2" units="%">10</constant>
<constant name="egoRPM2" units="RPM">1300</constant>
<constant name="egoSwitch2" units="v">0.510</constant>
<constant name="egoTemp2" units="C">18</constant>
<constant name="egoType2">"Narrow band"</constant>
<constant name="engineType2">"Even fire"</constant>
<constant name="fastIdleT2" units="C">-40.0</constant>
<constant name="injOpen2" units="ms">1.0</constant>
<constant name="injPwmP2" units="%">100</constant>
<constant name="injPwmT2" units="ms">25.5</constant>
<constant name="mapBins2" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
140
</constant>
<constant name="mapType2">"250 kPa"</constant>
<constant name="matType2">"GM"</constant>
<constant name="nCylinders2">"8"</constant>
<constant name="nInjectors2">"8"</constant>
<constant name="primePulse2" units="ms">1.3</constant>
<constant name="reqFuel2" units="ms">15.5</constant>
<constant name="rpmBins2" rows="12" units="RPM">
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6500
7000
</constant>
<constant name="rpmk2">1500</constant>
<constant name="twoStroke2">"Four-stroke"</constant>
<constant cols="12" name="veBins2" rows="12" units="%">
39 40 41 44 44 44 45 45 45 46 47 50
47 47 51 51 50 50 50 50 51 55 56 60
52 55 55 57 60 61 61 65 67 70 72 75
59 60 60 65 66 70 70 70 72 74 77 80
61 63 65 65 68 70 72 75 77 80 84 85
65 72 72 74 74 75 75 77 79 83 89 90
70 74 74 75 75 77 77 78 82 86 95 95
75 77 79 73 82 82 82 85 87 89 99 100
</constant>
</page>
<page number="2" size="189">
<constant name="CrankAng" units="Deg">10</constant>
<constant name="FixAng" units="Deg">-10</constant>
<constant name="IdleAdv" units="Deg">-10</constant>
<constant name="IdleAdvCLT" units="C">-40.0</constant>
<constant name="IdleAdvRPM" units="RPM">0</constant>
<constant name="IdleAdvTPS" units="ADC">0</constant>
<constant name="IdleDelayTime" units="sec">1</constant>
<constant name="IgHold">1</constant>
<constant name="IgInv">"Yes"</constant>
<constant name="Stg2ndParmDlt" units="kPa">0</constant>
<constant name="Stg2ndParmKPA" units="kPa">0</constant>
<constant name="StgCycles" units="cycles">25</constant>
<constant name="TrigAng" units="Deg">60</constant>
<constant name="TrigCrank">"Trigger Return"</constant>
<constant name="Trig_plus">"0"</constant>
<constant name="Trim" units="Deg">0</constant>
<constant cols="12" name="advTable1" rows="12" units="deg">
9 9 23 24 24 25 26 27 27 29 30 32
9 9 22 22 23 24 24 25 26 27 29 30
9 9 20 21 21 22 23 24 24 26 27 29
9 9 18 18 19 20 21 21 22 23 25 26
9 9 16 16 17 18 18 19 20 21 23 24
9 9 13 14 15 15 16 17 18 19 20 22
9 9 11 12 12 13 14 15 15 17 18 20
7 7 9 10 10 11 12 13 13 13 13 13
5 5 7 8 8 9 10 11 11 11 11 11
5 5 5 5 5 5 6 7 7 8 8 8
5 5 5 5 5 5 5 5 5 6 8 8
5 5 5 5 5 5 5 5 5 5 6 6
</constant>
<constant name="mapBins3" rows="12" units="kPa">
20
30
40
55
70
85
100
120
140
180
200
220
</constant>
<constant name="oddfire">"No"</constant>
<constant name="rpmBins3" rows="12" units="RPM">
600
1200
2000
2400
2800
3200
3600
4000
4400
5200
6000
6800
</constant>
<constant name="spare3_182">0</constant>
<constant name="spare3_183">0</constant>
<constant name="spare3_184">0</constant>
</page>
<page number="3" size="189">
<constant name="AFMUse">"No AFM *^"</constant>
<constant name="AccDecEnrich">"TPSdot*^(DT)"</constant>
<constant name="AccelMapASE">"Normal*^"</constant>
<constant name="AfrTar">"On"</constant>
<constant name="AfrTar2">"Off*^(DT)"</constant>
<constant name="AirCorAFM">"Use IAT"</constant>
<constant name="AlphBaroCor">"No"</constant>
<constant name="BarroHi" units="KPa">116</constant>
<constant name="BarroLow" units="KPa">67</constant>
<constant name="BooTbl2Use">"Dont Switch*^"</constant>
<constant name="BoostDir">"Increase boost"</constant>
<constant name="BoostMaxKn" units="KPa">30</constant>
<constant name="CltAdv">"Off"</constant>
<constant name="ConsBarCor">"Not Fitted*^"</constant>
<constant name="DecayAcPoint" units="mS">0.0</constant>
<constant name="DecayAccel">"Decay"</constant>
<constant name="DecelBoost">"Never*^"</constant>
<constant name="DecelKPa" units="kPa">255</constant>
<constant name="DtNos">"Bank1"</constant>
<constant name="EgoLim2" units="+-">5</constant>
<constant name="EgoLimKPa" units="KPa">255</constant>
<constant name="HCutLCSpark" units="Sparks">4</constant>
<constant name="HCutLCType">"Spark Cut Only"</constant>
<constant name="HCutSpark" units="Sparks">4</constant>
<constant name="HCutType">"Spark Cut Only"</constant>
<constant name="HardRevLim" units="rpm">6700</constant>
<constant name="IATBoost" units="C">0.0</constant>
<constant name="IATBoostSt" units="C">-40.0</constant>
<constant name="IStagedMode">"Off*^"</constant>
<constant name="IatAdvKpa" units="KPa">75</constant>
<constant name="IgAdvDeg" units="C">27.2</constant>
<constant name="IgAdvTemp" units="C">-2.2</constant>
<constant name="IgRetDeg" units="C">17.8</constant>
<constant name="IgRetTemp" units="C">17.8</constant>
<constant name="InvOut1">"Normal"</constant>
<constant name="InvOut2">"Normal"</constant>
<constant name="KPaDotBoost">"Never"</constant>
<constant name="KPaOn" units="KPa">80</constant>
<constant name="KPaTarg10" units="KPa">14</constant>
<constant name="KPaTarg100" units="KPa">0</constant>
<constant name="KPaTarg40" units="KPa">34</constant>
<constant name="KPaTarg60" units="KPa">54</constant>
<constant name="KnockAdv" units="Deg">1</constant>
<constant name="KnockBoost" units="KPa">0</constant>
<constant name="KnockKpa" units="KPa">255</constant>
<constant name="KnockMax" units="Deg">5</constant>
<constant name="KnockOn">"Off"</constant>
<constant name="KnockRet" units="Deg">2</constant>
<constant name="KnockRpm" units="RPM">5500</constant>
<constant name="KnockRpmL" units="RPM">1500</constant>
<constant name="KnockSb" units="Deg">1</constant>
<constant name="KnockTim" units="Sec">1</constant>
<constant name="KpaTPSTar">"Speed Density"</constant>
<constant name="LC_f_limangle" units="Deg">-10</constant>
<constant name="LC_f_slim" units="RPM">0</constant>
<constant name="LC_flatlim" units="RPM">5500</constant>
<constant name="LC_flatsel" units="RPM">25500</constant>
<constant name="LachDeg" units="Deg">5</constant>
<constant name="LachRpm" units="RPM">3500</constant>
<constant name="LachTps" units="Raw ADC">30</constant>
<constant name="LaunchLim" units="rpm">4000</constant>
<constant name="MaxIatAdv" units="Deg">5.3</constant>
<constant name="N2Odel_flat" units="s">0.00</constant>
<constant name="N2Odel_launch" units="s">0.00</constant>
<constant name="N2Oholdon" units="s">0.00</constant>
<constant name="NosAngle" units="Deg">18</constant>
<constant name="NosClt" units="C">-22.2</constant>
<constant name="NosHiKpa" units="KPa">120</constant>
<constant name="NosLagSystem">"Off"</constant>
<constant name="NosLowKpa" units="KPa">80</constant>
<constant name="NosPWHi" units="mSec">0.3</constant>
<constant name="NosPWLo" units="mSec">1.2</constant>
<constant name="NosRpm" units="RPM">3000</constant>
<constant name="NosRpmMax" units="RPM">6000</constant>
<constant name="NosTps" units="Raw">200</constant>
<constant name="OLoopEgo">"TPS"</constant>
<constant name="Out1UpLim" units="raw byte or deg F +40">0</constant>
<constant name="Out2UpLim" units="raw byte or deg F +40">0</constant>
<constant name="Out3_Out1">"Source"</constant>
<constant name="OvrBCutType">"Spark Cut Only"</constant>
<constant name="OvrBKpa" units="KPa">225</constant>
<constant name="OvrRunC">"Off"</constant>
<constant name="OvrRunClt" units="C">60</constant>
<constant name="OvrRunKpa" units="KPa">20</constant>
<constant name="OvrRunRpm" units="RPM">1700</constant>
<constant name="OvrRunTimr" units="Sec">0</constant>
<constant name="OvrRunTps" units="Raw ADC">5</constant>
<constant name="Pambient" units="kPa">100</constant>
<constant name="RPM1S" units="3000RPM/Sec or 5%Slip">0.0</constant>
<constant name="RPM2S" units="4000RPM/Sec or 15%Slip">10.0</constant>
<constant name="RPM3S" units="6000RPM/Sec or 30%Slip">15.0</constant>
<constant name="RPM4S" units="10000RPM/Sec or 70%Slip ">20.0</constant>
<constant name="RPMAE1" units="RPM">5500</constant>
<constant name="RPMAE2" units="RPM">3500</constant>
<constant name="RPMAE3" units="RPM">2000</constant>
<constant name="RPMAE4" units="RPM">500</constant>
<constant name="RPMBAsedAE">"Normal AE*^"</constant>
<constant name="RPMThresh" units="RPM/Sec">2000</constant>
<constant name="RPMmS1" units="mS">0.1</constant>
<constant name="RPMmS2" units="mS">1.0</constant>
<constant name="RPMmS3" units="mS">1.5</constant>
<constant name="RPMmS4" units="mS">2.0</constant>
<constant name="ST2Delay" units="Sec">0.0</constant>
<constant name="STTable2On">"Spark Table1^"</constant>
<constant name="ScaleFac">255</constant>
<constant name="ShiftLower" units="rpm">5800</constant>
<constant name="ShiftUpper" units="rpm">6000</constant>
<constant name="SoftLimMax" units="s">2.0</constant>
<constant name="SoftLimRetard" units="deg">10</constant>
<constant name="SoftRevLim" units="rpm">6600</constant>
<constant name="SparkCutBNum" units="Sparks">4</constant>
<constant name="SparkCutBase" units="Sparks">10</constant>
<constant name="StagedAnd">"One condition"</constant>
<constant name="StagedMAP2nd">"Off*^"</constant>
<constant name="StartWIKPa" units="KPa">120</constant>
<constant name="StgDelta">3</constant>
<constant name="StgTrans">25</constant>
<constant name="TPSAFRPoint" units="Raw ADC">255</constant>
<constant name="TPSBooIAT" units="Raw ADC">0</constant>
<constant name="TPSRPMTarg">"TPS"</constant>
<constant name="TPSTar">"Always"</constant>
<constant name="TargetB1" units="Raw Value">6</constant>
<constant name="TargetB2" units="Raw Value">26</constant>
<constant name="TargetB3" units="Raw Value">46</constant>
<constant name="TargetB4" units="Raw Value">0</constant>
<constant name="TpsOn" units="Raw">192</constant>
<constant name="TractCySec">"RPM stable for 0.1S"</constant>
<constant name="TractCyc1" units="3000RPM/Sec or 5%Slip">3</constant>
<constant name="TractCyc2" units="4000RPM/Sec or 15%Slip">5</constant>
<constant name="TractCyc3" units="6000RPM/Sec or 30%Slip">8</constant>
<constant name="TractCyc4" units="10000RPM/Sec or 70%Slip">12</constant>
<constant name="TractMode">"RPM Based"</constant>
<constant name="TractNOS">"No"</constant>
<constant name="TractRet1" units="3000RPM/Sec or 5%Slip">0</constant>
<constant name="TractRet2" units="4000RPM/Sec or 15%Slip">20</constant>
<constant name="TractRet3" units="6000RPM/Sec or 30%Slip">20</constant>
<constant name="TractRet4" units="10000RPM/Sec or 70%Slip">30</constant>
<constant name="TractSC1" units="3000RPM/Sec or 5%Slip">0</constant>
<constant name="TractSC2" units="4000RPM/Sec or 15%Slip">0</constant>
<constant name="TractSC3" units="6000RPM/Sec or 30%Slip">1</constant>
<constant name="TractSC4" units="10000RPM/Sec or 70%Slip">2</constant>
<constant name="TractScale" units="%">49</constant>
<constant name="TractSlip" units="%">10</constant>
<constant name="TractSlipH" units="%">2</constant>
<constant name="TractVSSMax" units="V">5.00</constant>
<constant name="TractVSSMin" units="V">0.00</constant>
<constant name="TractionOn">"Off*^"</constant>
<constant name="UseVE3">"Dont switch*^(DT)"</constant>
<constant name="VE3Delay" units="Sec">0.0</constant>
<constant name="VLaunch">"Off"</constant>
<constant name="WaterIIat" units="C">59.9</constant>
<constant name="WaterIRpm" units="RPM">3500</constant>
<constant name="WaterInj">"Off*"</constant>
<constant name="bcUpdateRate" units="ms">10</constant>
<constant name="bc_max_diff" units="kPa">255</constant>
<constant name="boostUse">"Output1*^"</constant>
<constant name="dGain" units="%">2.0</constant>
<constant name="dualdizzy">"Normal"</constant>
<constant name="dwellcont">"Dwell control"</constant>
<constant name="dwellcrank" units="ms">3.0</constant>
<constant name="dwellduty50">"75% duty cycle*^"</constant>
<constant name="dwellrun" units="ms">2.5</constant>
<constant name="edis">"Off*^"</constant>
<constant name="edismulti">"Off*^"</constant>
<constant name="edismultirpm" units="rpm">1100</constant>
<constant name="efanofftemp" units="C">2.8</constant>
<constant name="efanontemp" units="C">52.2</constant>
<constant name="falsetrig_dis">"Enabled*"</constant>
<constant name="fidleUse">"Idle control*"</constant>
<constant name="freqDiv">"13.0 Hz"</constant>
<constant name="hei7">"Off*^"</constant>
<constant name="hybridAN">"Off*^"</constant>
<constant name="ignmode">12</constant>
<constant name="inj1g">"on*^"</constant>
<constant name="inj2cr">"On*^"</constant>
<constant name="inj2g">"on*^"</constant>
<constant name="inj2t">"1*^"</constant>
<constant name="latency" units="us">0</constant>
<constant name="launchUse">"Off*^"</constant>
<constant name="led17Use">"Spark output A"</constant>
<constant name="led18Use">"Spark output C"</constant>
<constant name="led18_2Use">"1"</constant>
<constant name="led19Use">"Spark output B"</constant>
<constant name="maeBins4" rows="4" units="ms">
2.0
5.0
10.5
15.0
</constant>
<constant name="maeRates4" rows="4" units="ms">
50
100
150
250
</constant>
<constant name="mapProportion4">"TPSdot*^(DT)"</constant>
<constant name="mapThresh4" units="kPa/s">50</constant>
<constant name="mindischg" units="ms">0.1</constant>
<constant name="miss2nd">"no missing"</constant>
<constant name="msnsCyl">"Off*"</constant>
<constant name="neonCrank">"Off*^"</constant>
<constant name="nitrousUse">"Off*"</constant>
<constant name="numteeth">60</constant>
<constant name="onetwo">"-2"</constant>
<constant name="out1Hysis" units="raw byte or deg F">0</constant>
<constant name="out1lim" units="raw byte or deg F +40">0</constant>
<constant name="out1src">"Off*"</constant>
<constant name="out2Hysis" units="raw byte or deg F">0</constant>
<constant name="out2lim" units="raw byte or deg F +40">0</constant>
<constant name="out2src">"Off*"</constant>
<constant name="out3Timer" units="Sec">0.0</constant>
<constant name="out3lim" units="raw byte or deg F +40">0</constant>
<constant name="out3sparkd">"Output3"</constant>
<constant name="out3src">"Off*"</constant>
<constant name="out4FAN">"Source"</constant>
<constant name="out4lim" units="raw byte or deg F +40">0</constant>
<constant name="out4src">"Off*"</constant>
<constant name="pGain" units="%">25.1</constant>
<constant name="rotaryFDign">"FC Trailing"</constant>
<constant name="shiftUse">"Off*^"</constant>
<constant name="spkeop">"Shiftlight"</constant>
<constant name="spkfop">"Knock input"</constant>
<constant name="tachconf">"X5 (JS3)"</constant>
<constant name="tachconfdiv">"Normal"</constant>
<constant name="taeBins4" rows="4" units="ms">
1.0
2.0
4.0
8.0
</constant>
<constant name="taeColdA4" units="ms">0.5</constant>
<constant name="taeColdM4" units="%">120</constant>
<constant name="taeIgnCount">"Sec*^"</constant>
<constant name="taeRates4" rows="4" units="ms">
1.0
3.9
8.0
15.1
</constant>
<constant name="taeTime4" units="ms">0.5</constant>
<constant name="tdePct4" units="%">100</constant>
<constant name="tfi">"Off*^"</constant>
<constant name="toy_dli">"Normal*"</constant>
<constant name="tpsThresh4" units="v/s">0.977</constant>
<constant name="trig1">6</constant>
<constant name="trig1ret">14</constant>
<constant name="trig2">26</constant>
<constant name="trig2fall">"falling (like IRQ)"</constant>
<constant name="trig2ret">34</constant>
<constant name="trig3">46</constant>
<constant name="trig3ret">54</constant>
<constant name="trig4">0</constant>
<constant name="trig4ret">0</constant>
<constant name="trig5">0</constant>
<constant name="trig5ret">0</constant>
<constant name="trig6">0</constant>
<constant name="trig6ret">0</constant>
<constant name="wd_2trig">"Off"</constant>
<constant name="wheel_old">"025 style"</constant>
<constant name="wheelon">"Generic wheel"</constant>
<constant name="whlsim">"off"</constant>
<constant name="whlsimcnt">3</constant>
<constant name="x2use">"Water inj"</constant>
</page>
<page number="4" size="189">
<constant cols="12" name="advTable2" rows="12" units="deg">
9 9 10 15 22 32 36 36 36 36 36 36
9 9 10 15 21 30 32 32 32 32 32 32
10 10 13 15 20 28 30 30 30 30 30 30
10 10 13 15 19 27 28 28 28 28 28 28
10 10 13 15 19 23 26 26 26 26 26 26
10 10 11 14 17 22 24 24 24 24 24 24
10 10 10 13 16 21 23 23 23 23 23 23
10 10 9 11 15 20 22 22 22 22 22 22
10 10 8 10 14 19 19 19 19 19 19 19
</constant>
<constant name="mapBins4" rows="12" units="kPa">
30
40
50
60
70
80
90
100
110
120
130
140
</constant>
<constant name="rpmBins4" rows="12" units="RPM">
500
700
1300
2000
3000
4000
5000
6000
6100
6200
6300
6400
</constant>
</page>
<page number="5" size="189">
<constant name="ASEFixDe">"Decay *^"</constant>
<constant name="ASEFixTemp" units="C">99.9</constant>
<constant name="ASEFixTim">10</constant>
<constant name="ASETable1" units="%">30</constant>
<constant name="ASETable10" units="%">5</constant>
<constant name="ASETable2" units="%">20</constant>
<constant name="ASETable3" units="%">15</constant>
<constant name="ASETable4" units="%">12</constant>
<constant name="ASETable5" units="%">10</constant>
<constant name="ASETable6" units="%">9</constant>
<constant name="ASETable7" units="%">8</constant>
<constant name="ASETable8" units="%">7</constant>
<constant name="ASETable9" units="%">6</constant>
<constant name="ASETime">200</constant>
<constant name="VEFixASE">"Normal MAP *^"</constant>
<constant name="VEFixValue" units="kpa">67</constant>
<constant name="aseIgnCount">"Cycles*^"</constant>
<constant name="mapBins5" rows="12" units="kPa">
20
30
40
50
60
75
90
100
110
120
130
150
</constant>
<constant name="rpmBins5" rows="12" units="RPM">
500
1000
1500
2000
2800
3600
4400
5200
5500
6000
6200
6500
</constant>
<constant cols="12" name="veBins3" rows="12" units="%">
</constant>
</page>
<page number="6" size="189">
<constant name="Nos2Angle" units="Deg">0</constant>
<constant name="Nos2PWHi" units="mSec">0.0</constant>
<constant name="Nos2PWLo" units="mSec">0.0</constant>
<constant name="Nos2Rpm" units="RPM">25500</constant>
<constant name="Nos2RpmMax" units="RPM">25500</constant>
<constant name="Nos2delay" units="s">0.00</constant>
<constant cols="8" name="afrBins1" rows="8" units="AFR">
13.2 14.8 14.8 14.8 14.8 14.8 14.8 13.4
13.2 14.3 14.8 14.8 14.8 14.8 14.7 13.2
13.2 14.3 14.3 14.8 14.8 14.8 14.3 13.2
14.1 14.3 14.3 14.7 14.7 14.4 14.0 13.2
14.1 14.3 14.3 14.3 14.1 14.1 13.2 12.2
13.7 13.7 13.7 13.5 13.5 13.2 12.5 11.8
12.5 12.5 12.5 12.5 12.2 11.9 11.9 11.8
11.9 11.8 11.8 11.5 11.3 11.0 10.8 10.8
</constant>
<constant cols="8" name="afrBins2" rows="8" units="AFR">
15.9 15.9 15.9 15.9 15.9 15.9 15.9 15.9
14.8 14.8 14.8 14.8 14.8 14.8 14.8 14.8
14.6 14.6 14.6 14.6 14.6 14.6 14.6 14.6
14.3 14.3 14.3 14.3 14.3 14.3 14.3 14.3
</constant>
<constant name="mapBins6" rows="8" units="kPa">
15
50
60
90
115
145
170
200
</constant>
<constant name="mapBins7" rows="8" units="kPa">
15
30
50
60
90
100
110
150
</constant>
<constant name="outaoffs">"0"</constant>
<constant name="outaoffv" units="deg">0.0</constant>
<constant name="outboffs">"0"</constant>
<constant name="outboffv" units="deg">0.0</constant>
<constant name="outcoffs">"0"</constant>
<constant name="outcoffv" units="deg">0.0</constant>
<constant name="outdoffs">"0"</constant>
<constant name="outdoffv" units="deg">0.0</constant>
<constant name="outeoffs">"0"</constant>
<constant name="outeoffv" units="deg">0.0</constant>
<constant name="outfoffs">"0"</constant>
<constant name="outfoffv" units="deg">0.0</constant>
<constant name="rpmBins6" rows="8" units="RPM">
500
1000
2000
2800
3500
4200
5500
7000
</constant>
<constant name="rpmBins7" rows="8" units="RPM">
500
1000
1500
2000
2800
3600
5000
6000
</constant>
</page>
<page number="7" size="189">
<constant cols="6" name="bcBins1" rows="6" units="kpa">
100 100 100 100 100 100
100 120 120 120 120 120
</constant>
<constant cols="6" name="bcBins2" rows="6" units="duty">
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
20 20 20 20 20 20
</constant>
<constant cols="6" name="bcBins3" rows="6" units="kpa">
</constant>
<constant name="bcrpmBins1" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bcrpmBins2" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bcrpmBins3" rows="6" units="RPM">
1000
2000
3000
4000
5000
7000
</constant>
<constant name="bctpsBins1" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
<constant name="bctpsBins2" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
<constant name="bctpsBins3" rows="6" units="tps%">
20
30
40
50
70
90
</constant>
</page>
<page number="8" size="189">
<constant name="AlwaysPrime">"Prime Pulse>0*^"</constant>
<constant name="CrankPWT1" units="mS">18.1</constant>
<constant name="CrankPWT10" units="mS">3.1</constant>
<constant name="CrankPWT2" units="mS">12.1</constant>
<constant name="CrankPWT3" units="mS">8.1</constant>
<constant name="CrankPWT4" units="mS">6.1</constant>
<constant name="CrankPWT5" units="mS">5.6</constant>
<constant name="CrankPWT6" units="mS">5.1</constant>
<constant name="CrankPWT7" units="mS">4.6</constant>
<constant name="CrankPWT8" units="mS">4.1</constant>
<constant name="CrankPWT9" units="mS">3.6</constant>
<constant name="CrankRPM" units="rpm">300</constant>
<constant name="ExFuelCrank">"Off"</constant>
<constant name="ExtraFMult" units="%">25</constant>
<constant name="IATCTemp" rows="7" units="C">
18
25
34
43
52
61
70
</constant>
<constant name="IATCor">"Normal Correction*^"</constant>
<constant name="IATCorS" rows="7" units="%">
100
98
96
94
92
90
88
</constant>
<constant name="IATCorTy">"Coolant Corrected"</constant>
<constant name="Idashdelay" units="x 0.01sec">0</constant>
<constant name="Ideadbnd" units="+/- RPM">30</constant>
<constant name="PrimeLate">"Power Up*^"</constant>
<constant name="PrimePulse" units="mS">0.4</constant>
<constant name="PrimeTBox">"Priming Table"</constant>
<constant name="RPMRedHi" units="RPM">3000</constant>
<constant name="RPMRedLo" units="RPM">1000</constant>
<constant name="crankpwip">"CLT only*^"</constant>
<constant name="fastIdleRPM" units="RPM">1100</constant>
<constant name="fastIdleTemp" units="C">65</constant>
<constant name="fixedsplit" units="deg">-10</constant>
<constant name="ictlrpm1" units="lo RPM">30</constant>
<constant name="ictlrpm2" units="hi RPM">100</constant>
<constant name="idlePeriod2" units="x 0.01sec">10</constant>
<constant name="idleThresh" units="ADC">30</constant>
<constant name="idle_dc_hi" units="dc">0</constant>
<constant name="idle_dc_lo" units="dc">50</constant>
<constant name="idleclosedc" units="dc">0</constant>
<constant name="idlecrankdc" units="dc">50</constant>
<constant name="idledashdc" units="dc">45</constant>
<constant name="idledelayclock" units="x 0.01sec">1</constant>
<constant name="idlefreq" units="10000/x = Frequency">100</constant>
<constant name="idlemindc" units="dc">27</constant>
<constant name="idleperiod" units="x 0.01sec">25</constant>
<constant name="idlestartclk" units="x 0.01sec">10</constant>
<constant name="irestorerpm" units="RPM">150</constant>
<constant name="pwmIdle">"B&G On-Off*^"</constant>
<constant name="pwmidlewhen">"Warmup only"</constant>
<constant name="rotary2">"Off"</constant>
<constant name="slowIdleRPM" units="RPM">650</constant>
<constant name="slowIdleTemp" units="C">52</constant>
<constant cols="6" name="splitTable" rows="6" units="deg">
-0 21 21 21 21 21
-0 16 16 16 16 16
-0 10 10 10 10 10
-0 5 5 5 5 5
-0 -0 -0 -0 -0 -0
-1 -1 -1 -1 -1 -1
</constant>
<constant name="splitkpaBins" rows="6" units="kpa">
40
50
60
80
105
106
</constant>
<constant name="splitrpmBins" rows="6" units="RPM">
600
800
3000
4000
5000
7000
</constant>
<constant name="tpsflood" units="raw">195</constant>
<constant name="wueBins9" rows="10" units="%">
180
140
135
130
128
125
120
118
115
100
</constant>
</page>
</msq>
Post by M20_fever » Mon Nov 15, 2010 10:05 pm
um, wut? Never seen an msq like that?
Post by Yoshi » Mon Nov 15, 2010 11:21 pm
save it as an MSQ. open notepad and save as.
Post by M20_fever » Tue Nov 16, 2010 3:02 am
I see, well that means nothing to me, I can hardly understand the msq in TS format. I'm still trying to figure out how to get a RPM reading. Chris325IX said he used a jumper to simulate a cam sensor, but I'm not going to be running a cam sensor so I don't think thats the way I should do it. Besides, I have my MS plugged into the MS so I wouldn't know where to jump it to since I can't access the pins, unless i open the case and jump it from the back?
Post by Yoshi » Tue Nov 16, 2010 3:17 pm
In the MS1 world, you have to select an option on megatune to use that knob. It was called "stim for wheel". The cam sensor, you just need to disable sequential and it shouldn't need it. I'm not sure if where the option is for that. I need to read up but I'm kind of busy at work.
Post by M20_fever » Tue Nov 16, 2010 5:04 pm
Have you tried using MT with MS3, because everyone else I talk to, including DIY says MT does not support MS3. I'm only working in TS so I have no idea what your describing when talking about MT.
I'm making headway slowly, I was pointed to a nice write up on setting the new Jimstim up for toothed wheel simulation using a jumper on the stim to pin 24 of the DB37. Sounds good but I haven't got it totally figured out yet. :)
Post by Yoshi » Tue Nov 16, 2010 5:27 pm
Never touched an MS3 so I have no experience with anything. All my input is conjecture. I haven't even started reading up on MS3 :-p
Post by M20_fever » Tue Nov 16, 2010 10:46 pm
Gotcha, it's a whole new world here in MS3 land. :) I've got the stim reading RPM in TS, but only up to 2293ish RPM then it loses sync. I'm working with a couple people to resolve this, I'll update when I get it sorted.
Post by M20_fever » Thu Oct 31, 2013 3:39 pm
Well it only took 3 years, but I'll update this thread since I'm getting back into this install. I got the RPM issue resolved by correctly setting the JP1 and J1 jumpers on the 3.57 board to 1 & 2 and 3 & 4 respectively. I ended up getting up to 18k rpm after fixing that, so should be fine for my m20, lol.
I'm going to be plucking along at this over the coming months so I'll update when it makes sense. For now, I'm going to install the setup as I bought it, running wasted spark with the 3000GT coils and coil driver using the questionable harness that came with it. Budget is the driving factor here since the Chevelle is still eating most of my car money. If I validate the harness I 'should' have everything I need to get the car running on the MS, then its time dust off that M90 that's been sitting on my shelf for a couple years.
Post by Nsquared97 » Fri Nov 01, 2013 5:22 am
Me likes the sound of this...
