MS3 comprehensive experience thread
Re: MS3 comprehensive experience thread
Postby M20_fever » Sat Nov 09, 2013 5:18 pm
right, that's what I sad. I'll add a relay for the coil driver, and run the rest of the harness through the relay box on the drivers side next to the c101 plug. Am I just all wet in my thinking here?
Postby Yoshi » Sun Nov 10, 2013 12:28 am
I think so...
Postby M20_fever » Sun Nov 10, 2013 1:34 am
you think I'm right or wrong? lol.
Postby Yoshi » Mon Nov 11, 2013 1:18 am
I run my harness on the passenger's side. but whatever you want to do.
Postby M20_fever » Mon Nov 11, 2013 3:00 am
So you just pull the OE relay/fuse box from the driver side and toss it, then build your own relay block for your harness?
Postby Yoshi » Mon Nov 11, 2013 1:02 pm
I leave the stock fuse/relay fuse box. I relocate the factory main relays (O2/main/fuel) to the M3 harness cover. Why bother ripping out the fuse box? Those do body stuff, not really engine stuff.
Postby M20_fever » Mon Nov 11, 2013 2:31 pm
I see. I'll just have to see how it goes. I was planning on running the Ms harnesses through the main relay box and only adding the missing relays on the m3 harness cover.
Postby M20_fever » Wed Nov 13, 2013 2:49 am
yay!
Postby Yoshi » Wed Nov 13, 2013 1:07 pm
That was fast. And damn they send it with diagrams now lol. LMK if my wiring and shizzle helps out.
Postby M20_fever » Wed Nov 13, 2013 2:00 pm
oh I'll definitely be using your info. Already used a lot of it to set up my msq. I'm very happy with the quality of these harnesses, well worth the ~$200 it cost. I couldn't have done any better and its going to save me a ton of time and headaches. I'm hoping to start the instal this weekend.
Postby Yoshi » Wed Nov 13, 2013 2:26 pm
Yea... after I bought that harness the first time, I looked at it for 10 seconds and went "why would I NOT buy this?". Saves so much time. Also eliminates a lot of guess work. I've had issues in the past with the DIY connector not connecting.
Postby M20_fever » Wed Nov 13, 2013 4:20 pm
yeah, I passed up a killer deal on a set of diy harnesses from a forum member because I didn't want to deal with assembling it myself, and never being totally confident on my work.
Return to “Forced Induction”
