Megasquirt for dummies
Dot Communist
Re: Megasquirt for dummies
Postby Dot Communist » Fri Aug 14, 2009 3:26 am
Are all those megasquirt settings for the m50 or m20?
-Ryan Brock
Postby Yoshi » Fri Aug 14, 2009 12:08 pm
which settings? I would assume (unless its done by me recently) its all M20
Dot Communist
Postby Dot Communist » Fri Aug 14, 2009 8:03 pm
On the first page
-Ryan Brock
Postby Yoshi » Fri Aug 14, 2009 8:36 pm
you mean the specific parts? I didn't post settings.
Dot Communist
Postby Dot Communist » Fri Aug 14, 2009 9:11 pm
-Ryan Brock
BMWIS
Postby BMWIS » Mon Oct 12, 2009 10:29 am
The megamanual, and other reading I have done on the MegaSquirt.info site says that MS1 does not support an idle control valve.
How is idle adjusted?
Can the MS1 be modified to control an idle control valve?
Postby Yoshi » Mon Oct 12, 2009 1:14 pm
You have to modify the MS to do an idle control valve. It can be done and has been done quite a few times. I haven't run one on all my cars though and I can always get a good idle. Tends to be 800rpms to 1200 rpms though. some ppl prefer 500rpm idles.
joecrotch
Postby joecrotch » Tue Jul 27, 2010 3:41 am
god i really want to do the MS thing but its so scary. i sold my ms1 set up because i was scared. i kept telling myself I was selling it to get msII.
i have a question what is kpa?
Postby Yoshi » Tue Jul 27, 2010 12:47 pm
kilo pascals It's a unit of pressure. 100kpa is atmospheric pressure. When you see boost gauges say 0psi, it's really not 0, it's atmosphere.
joecrotch
Postby joecrotch » Wed Jul 28, 2010 2:20 am
nice i actually learned a lot about that in aviation school but never had heard the term before. thanks!
Postby M20_fever » Wed Nov 03, 2010 10:33 pm
It seems DIY doesn't really have any MS3 specific info on their site yet, is there someplace to find some good beginner info on installing/setting up my MS3 kit?
Will the stim you posted earlier for $70 still work with MS3?
Postby Yoshi » Wed Nov 03, 2010 10:39 pm
the install is basically the same. just more sensors. The stim will work AFAIK. you can email diy I suppose.
Postby M20_fever » Wed Nov 03, 2010 11:54 pm
SO does the megamanual still cover enough that applies to MS3 to be worth reading?
Postby Yoshi » Thu Nov 04, 2010 1:48 am
I think theres an MS3 specific part of the manual. I'm actually pretty sure of it. I read parts of it.
Postby M20_fever » Thu Nov 04, 2010 2:08 am
I'm reading the manual now, seems pretty straight forward.
Return to “Forced Induction”
