best turbo for m50tu
610EURO
Postby 610EURO » Sat May 30, 2009 4:52 am
like the title says, i have a vanos m50. whats the best holset for this ? im looking to run 8-10 psi. the motor is all stock. i dont plan on raising the boost higher then that now but a turbo that would allow for higher boost later on would be ideal. so what do you guys reccomend ? hx40 ? hx50 ? hx35 ? h1C ? some bastard child i dont know about ?
Re: best turbo for m50tu
Postby M20_fever » Sat May 30, 2009 5:50 am
I would say HX40, but look at the compressor maps and see which one fits your goals.
BimmerJake
Postby BimmerJake » Sat May 30, 2009 2:11 pm
is your e30 flat black? *drool* :mrgreen:
Douglas Adams wrote:The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.
610EURO
Postby 610EURO » Sat May 30, 2009 2:15 pm
BimmerJake wrote:is your e30 flat black? *drool* :mrgreen:
satin :D
BimmerJake
Postby BimmerJake » Sat May 30, 2009 2:23 pm
it's almost exactly how i would love mine to be with the rims, the m50, the low sheen paint... except i have an unhealthy obsession with diving boards :lol:
Postby M20_fever » Sat May 30, 2009 6:48 pm
satin is one of may faves, but only when done well. If yours looks that good in person 618 then you sir are done well. :)
asuj158
Postby asuj158 » Sat May 30, 2009 11:22 pm
get a turbonetics t4 i have one on my m20 and love it
610EURO
Postby 610EURO » Sun May 31, 2009 3:45 am
BimmerJake wrote:it's almost exactly how i would love mine to be with the rims, the m50, the low sheen paint... except i have an unhealthy obsession with diving boards :lol:
well its an 86' so it had diving boards. i just didnt like them. my new DD has diving boards .. i still dont like em.
M20_fever wrote:satin is one of may faves, but only when done well. If yours looks that good in person 610* then you sir are done well. :)
it loos like this in person:
:lol:
asuj158 wrote:get a turbonetics t4 i have one on my m20 and love it
holset = cheaper
Postby Yoshi » Mon Jun 01, 2009 3:32 pm
HX35 will do you best. It's T3 flanged and from my research, will be best bang for your buck. T4s and HX40s will spool too late and laggy for your low boost application. H1Cs are also another option since they are also T3 flanged but tend to spool a bit later than HX35s (but sooner than HX40s IMO... or about the same).
IMO HX35 all the way. But I have one so I'm biased.
610EURO
Postby 610EURO » Mon Jun 01, 2009 4:26 pm
Yoshi wrote:HX35 will do you best. It's T3 flanged and from my research, will be best bang for your buck. T4s and HX40s will spool too late and laggy for your low boost application. H1Cs are also another option since they are also T3 flanged but tend to spool a bit later than HX35s (but sooner than HX40s IMO... or about the same).
sounds good. can i remove the internal wastegate and put on an external one or should i try and find a non-wastegated hx35 turbo ? if they exist. is there any difference between the hx35 years ? is there a specific one ui should be looking for ?
Postby Yoshi » Mon Jun 01, 2009 4:33 pm
Exhaust housings are interchangeable. Some ppl even do HX35/40 hybrids like T3/T4s. You should be able to either weld the WG shut on the housing or pick up another housing.
Although, there are different sized housings and you should be aware of what each does. EG Garretts haev A/R but Holset has CM^2. www.turbobyholset.com is a good place to ask those things. I don't know much about them myself.
610EURO
Postby 610EURO » Mon Jun 01, 2009 6:40 pm
will the hx40 bolt right to the rear of the hx35 ?
Postby Yoshi » Mon Jun 01, 2009 6:54 pm
I think its HX40 compressor side on an HX35 turbo. They should bolt right up. I'm fairly sure the HX40 exhaust housing will bolt onto an HX35 but that would make it T4 flanged and spool like SHIT.
Postby M20_fever » Mon Jun 01, 2009 8:12 pm
[quote="610EUROit loos like this in person:
:lol:
[/quote]
This made me laugh, hard. :lol:
Postby ten2doyle102 » Mon Jun 01, 2009 8:15 pm
I was a little confused by that photo....what happened....did I miss something?
Return to “Forced Induction”
