decent BOV and wastegate
Tchao
Re: decent BOV and wastegate
Post by Tchao » Wed Jun 10, 2009 6:44 am
Im confused now.
You are willing to make a real split pulse manifold but not willing to up the budget for more quality parts?
I would divert your resources to better stuff like ECU and turbo and run a normal entry manifold. You would be miles ahead of the crowd with just that. Instead of dicking around with a super nice split pulse....that is just 2x the headache and 2x the problems. Not worth it unless you know exactly what you are doing, in which case there would not of been this thread to begin with.
If you are building your own manifold, I suggest study up on some motorsport designs, and if you are cool enough, put it though some type of CFD or whatever. There are a few forums, but the most info I found was though honda-tech on making your own manifolds, look it up and see what some pro-fab guys have to share.
My advise, make a simple but well thought out regular manifold. Get a decent WG, decent turbo, and most importantly a decent ECU. Tune it right and have long lasting superfast E30. Keep it simple.
E30 M50nv
610EURO
Post by 610EURO » Wed Jun 10, 2009 7:16 am
Tchao wrote:Im confused now.
i have 24-7 free time so i cant afford the highest priced parts but i can take as long as it takes to fab a good manifold. it will be running MS so im not worried about ecu. building costs nothing, buying expensive parts is hard on the bank.
Post by Yoshi » Wed Jun 10, 2009 1:34 pm
building costs building materials. That can get pricey imo.
610EURO
Post by 610EURO » Wed Jun 10, 2009 4:01 pm
Yoshi wrote:building costs building materials. That can get pricey imo.
thats true but i highly doubt i could get near the $1500+ volk charges for his. dont get me wrong, his stuff is top notch. but imo its way pricey.plus i prefer to say i made this rather then i bought this.
Post by Yoshi » Wed Jun 10, 2009 4:02 pm
I'm probably just going to make my own log style or get a cast one and weld onto it.
anyone know how bad it is to weld SS to mild steel?
Post by M20_fever » Wed Jun 10, 2009 8:32 pm
The best way to successfully weld SS to MS or even Hardened Tool steel to MS is to use Magna 303 welding rod mfg by Magna Industrial, Australia. It has been tried and tested and is the only successful way to weld different steels and the weld has a tensile strength of 1,20000 psi, but these rods are expensive and suitable primarily for maintanence or repair welding
found here: http://cr4.globalspec.com/thread/6367
Post by Yoshi » Wed Jun 10, 2009 8:41 pm
I don't tig tho. Fuck it. I'm just going to make a new adapter.
BenFenner
Post by BenFenner » Thu Jun 11, 2009 2:32 pm
To answer the original question, these are the BOVs and WGs you're after.
http://www.jgstools.com/turbo/index2.html
Tial quality for less money.
Post by M20_fever » Thu Jun 11, 2009 7:12 pm
Ben, glad to see you made it over here, hope you stick around and share your boost knowledge.
Post by Yoshi » Thu Jun 11, 2009 7:41 pm
+1
Tchao
Post by Tchao » Thu Jun 11, 2009 8:42 pm
Yikes....$200 for a bypass valve, and doesnt even have a ball seat. No thanks.
$400 for a wastegaste...granted said piston instead of diaphragm, but that price is on par with a Synapes of equal size. (50mm)
E30 M50nv
610EURO
Post by 610EURO » Fri Jun 12, 2009 5:34 am
BenFenner wrote:To answer the original question, these are the BOVs and WGs you're after.
these are about the same price as the Tials. not really any savings.
BenFenner
Post by BenFenner » Thu Jun 18, 2009 4:16 pm
Hmm...
I haven't prices Tial in a long while. My mistake.
DonkeyPunch
Post by DonkeyPunch » Thu Jun 18, 2009 11:58 pm
I don't like the bosch plastic valves for one you
have to route it to the intake, or you have to run filters on them
because they stay open at idle.
and it kept chirping the turbo after about 12psi, but
I only ran one.
Then I got this turboxs "RFL" one. Looks like something
some old man would run in his mustang, but does the job.
No more turbo mating calls with it.
But cheapest for sure would be two plastic recirc valves.
My signature is to help me find my last post like a bookmark.
Should I make it flashy with colors, and a picture of my car?
This is fine... People will know it's me just by looking at this text,
not my screen name.BLUE or perhaps a large .gif. Hmm.
Post by Yoshi » Fri Jun 19, 2009 12:05 am
DonkeyPunch wrote: Then I got this turboxs "RFL" one. Looks like something
Thats what I have. Sounds pretty good too.
