Crank case check valve. Where to buy?
Postby Yoshi » Mon Jun 08, 2009 7:10 pm
I'm lazy and might hook my crank case vent to my charge piping or exhaust. But If I do either, I NEED a check valve to make sure boost doesn't find its way into my crank case. Ideas?
BimmerJake
Re: Crank case check valve. Where to buy?
Postby BimmerJake » Mon Jun 08, 2009 10:52 pm
how much pressure? you can get check valves at home depot for gas lines etc. but i don't really know how they're rated or anything.
Douglas Adams wrote:The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.
Postby Yoshi » Tue Jun 09, 2009 12:57 am
+-15psi I would say.
DonkeyPunch
Postby DonkeyPunch » Thu Jun 11, 2009 6:35 am
If you run your vent to your charge pipe you're
effectively putting a cork in on boost. = very bad. :oops:
My signature is to help me find my last post like a bookmark.
Should I make it flashy with colors, and a picture of my car?
This is fine... People will know it's me just by looking at this text,
not my screen name.BLUE or perhaps a large .gif. Hmm.
Postby Yoshi » Thu Jun 11, 2009 1:16 pm
Yea its not ideal. I want to make some stuff so I can hook it up in front of the turbo. But I need to fab piping for that.
