ok ladies, lets talk setup.
Post by M20_fever » Fri Oct 02, 2009 12:32 pm
So I am finally at a point where I can start buying components but I'\m not 100% on what I need to get where I want to be.
Here is what I do know:
I'll be going with MS, though I'm sure which one, thinking ms2v3 fuel & spark.
Holeset turbo, either HX35 or HX35/40 hybrid.
FMIC (ebay)
LC1 WB02
unknown BOV & WG
unknown exhaust mani (likely ebay)
e36 TPS
injectors...not sure.
and...
comments?
I want to push this engine, so if I get less than 600chp I will be disappointed. That is a starting point, I plan to eventually incorporate a nitrous system into equation as well. Eventually I would like to take a crack at Limmets record, but that is down the road. :mrgreen:
Re: ok ladies, lets talk setup.
Post by Yoshi » Fri Oct 02, 2009 1:28 pm
how many liters you got? hx35/40 might be a good shot. Injectors need to be sized for the power you aim for. So at least 70# sounds like it should give you what you need. Might want to wait for MS3 though. should be out soonish.
how much boost? Whats your comp ratio?
Post by M20_fever » Fri Oct 02, 2009 1:56 pm
2.8 liter fully forged (except crank), welded/o-ringed head w/ ARPs & +1mm intake valves, OE size exhaust valves, full port/polish. CR is stock 8.8:1. I'll be buying my MS in Dec, if MS3 is out by then fine, if not I'll get MS2 and upgrade to the MS3 chip when it comes out. I want to eventually hit 30 psi, but lets say 20 to start (want room to up boost as I get bored :)). I talked to Dan Pinder and he is running over 21 on his MS with a 4 bar MAP sensor so I think I can get to 30 with little trouble.
Post by Yoshi » Fri Oct 02, 2009 2:08 pm
i would say anything over 22ish would require some charge cooling (meth/water injection). *shrugs* but what do I know. I only aspired for 15psi lol.
Post by M20_fever » Fri Oct 02, 2009 2:24 pm
well, I can settle for 20psi until I get the nitrous going, that should cool the charge a bit, no? :)
Post by ten2doyle102 » Fri Oct 02, 2009 2:29 pm
That's going to be one hell of a setup there! I think of anything of 15 psi more than enough for me, but shooting for 20psi+ should make for a really fun car!! :)
Post by M20_fever » Fri Oct 02, 2009 4:32 pm
Yeah, I would really like to see this car hit the 9's in the 1/4 with full interior but that may be a stretch, even on wrinkle walls. I should start buying half shafts now, I'm going to need them. :twisted:
Post by ten2doyle102 » Fri Oct 02, 2009 5:53 pm
LOL at the Half shaft comment. Your probably right though! shooting for 9's is no easy feat!
Post by M20_fever » Fri Oct 02, 2009 5:57 pm
yeah, that is end goal, it will take some time to get there. I think I can hit 11's no problem on pump gas to start. I'll have 2 tunes, 1 for street on 93 oct and 1 for track on 116 avgas. Its going to be a long road though since I will have to put money other places as I increase power, like a cage and fuel cell, exterior kill switch etc.
nogapersnBMWs
Post by nogapersnBMWs » Sat Oct 03, 2009 12:59 am
M20_fever wrote:I want to eventually hit 30 psi, but lets say 20 to start (want room to up boost as I get bored :)).
That would be extremely impressive boost for that engine (with 20 psi as a starting point)!
Post by M20_fever » Sat Oct 03, 2009 3:05 am
yeah I have been planning this build for a good while so I know the engine can handle it. It will be a several year journey but I will bring the most powerful M20 title to the United States. :mrgreen: 8)
Dot Communist
Post by Dot Communist » Sat Oct 03, 2009 3:40 am
Have you looked at the PNP megasquirts?
-Ryan Brock
Post by M20_fever » Sat Oct 03, 2009 6:56 am
you mean the ones rs4pro sells on the tech?
nogapersnBMWs
Post by nogapersnBMWs » Sat Oct 03, 2009 2:42 pm
What type of speed density/air measurement system are you planning to use. Stock AFM, MAS, Alpha-N, MAP input on MS?
Post by ten2doyle102 » Sat Oct 03, 2009 7:28 pm
M20_fever wrote:yeah I have been planning this build for a good while so I know the engine can handle it. It will be a several year journey but I will bring the most powerful M20 title to the United States. :mrgreen: 8)
How much power are you looking to put down???
