MVRK - DIY - 24V Oil Filter Housing and Gasket swap
mvrk10256
Postby mvrk10256 » Sat Feb 04, 2012 9:25 pm
This DIY will cover replacing your OFH and the gasket. Most of you will not be replacing the unit itself but rather the gasket. I have had some issues that required a swap. Anyway its all here as usual .
*****DISCONNECT THE BATTERY*******
1. Intake boot/MAF/filter comes off.
2. Fan comes of. If mechanical use a 32MM wrench, if electric simply remove.
3. Belt comes off next - 8MM allen key
4.Remove the 10mm and 13mm nuts on the back of the alternator.
5. Remove alternator: - remove idler pully cap and remove using a 16mm or 5/8" socket, the bottom bolt is harder. I suggest a stationary socket in front, and a open wrench on the back. Use the wrench to ratchet it off.
6.REmove the top two bolts of steering pump (13mm)
7. Remove the bolts from the oil filter housing - They are different. The top of engine corresponds to right hand side of the picture, going down as you go left.
8.If your swapping housing remove the pully - 3 x 13mm bolts
9.Here is a series of comparison. The middle is a canadian NV OFH, The left is the weird one i had, and the right is a vanos M50 one.
10. The one I had had a weird valve in it.
Now just put it all back together. Good Luck.
-Maksim
Re: MVRK - DIY - Oil Filter Housing and Gasket swap
Postby Yoshi » Sat Feb 04, 2012 9:31 pm
can you change the title to 24v?
I've had to do this a few times... not fun at all.
Postby Nsquared97 » Sat Feb 04, 2012 11:16 pm
This looks a hell of a lot easier for a M20.
Postby M20_fever » Sun Feb 05, 2012 1:09 am
yeah, specify this is a 24v write up and I'll sticky it.
mvrk10256
Postby mvrk10256 » Sun Feb 05, 2012 6:53 am
Yoshi wrote:can you change the title to 24v?
Its not that bad. Worst part is the lower bolt on alternator. PITA.
Nsquared97 wrote:This looks a hell of a lot easier for a M20.
Lol.
M20_fever wrote:yeah, specify this is a 24v write up and I'll sticky it.
For a couple of mods you guys are non intrusive. I added the 24V to the title.
-Maksim
Re: MVRK - DIY - 24V Oil Filter Housing and Gasket swap
Postby M20_fever » Sun Feb 05, 2012 9:17 pm
more like lazy, lol.
Sticky.
mvrk10256
Postby mvrk10256 » Tue Feb 07, 2012 10:21 pm
11 stickies and counting.
-Maksim
Postby M20_fever » Wed Feb 08, 2012 12:27 am
hehe, keep 'em comin'!
mvrk10256
Postby mvrk10256 » Sat Feb 11, 2012 5:15 pm
M20_fever wrote:hehe, keep 'em comin'!
Lol. the list is dwindling. Not really sure what else I need to do to this car... (as long as nothing breaks). Turbo maybe....
-Maksim
