M50 in early model. Crank but no start
Postby Yoshi » Mon May 07, 2012 6:36 pm
Doing an M50 swap for a bud. Hooked up everything as best as I can. There was an I hook with red wires. Assumed that's power. Saw another one with brown and brown and orange. Hooked that to ground.
I can bridge the fuel pump relay and the fuel pump will turn on. When cranking, fuel pump will not turn on. Stupid cam/crank sensors use the same plug so we tried swapping them around a few times. No dice. Thoughts?
