24V Swap info
Re: 24V Swap info
Postby ponycarman » Wed Sep 15, 2010 12:23 am
Awesome! I would love to see pics of that!
Bkack318is
Re: 24V Swap info
Postby Bkack318is » Wed Sep 15, 2010 1:07 am
i will try to find pics tonight if i cant find them ill take some tomorrow!
Re: 24V Swap info
Postby ten2doyle102 » Wed Sep 15, 2010 12:55 pm
That's pretty odd that you can use that. In for pics!
Bkack318is
Re: 24V Swap info
Postby Bkack318is » Wed Sep 15, 2010 4:08 pm
there also on the tech... i would post the pics up but photo bucket is tooooo slow on the work comp!!
plmichal
Re: 24V Swap info
Postby plmichal » Thu Sep 16, 2010 2:54 am
find this thread much more informative than the one on tech an r3v... thanks yoshi!
DOHC non-Vanos
EricT
Re: 24V Swap info
Postby EricT » Fri Sep 17, 2010 11:02 pm
I'm using the e32.... 740i brake booster and master with a 2002 reservoir. Requires a little modding. You hafta slot the holes in the pedalbox/firewall about 3/4".... then take the clevis mount off the stock booster, cut about 5/8" off the e32 clevis and weld the stock clevis on there. That will get you lined up perfect with the clutch pedal. Just tweak the factory hardlines a little bit and your set :) The brake power is INSANE!!!!!
I'd also like to add that if your faint at heart about wiring, and the akg pin to pin chart merely gets the car running........I mod harnesses so they look like the m5x/s5x obdI engine harness came in the e30 from the factory..... for $150 shipped back to your door. If you provide the c101, c104(early models), and the 3 prong plug for the oil level if you need it I do it for $120 or so depending on my mood. Normally cheaper. I label all the sensor plugs so you aren't guessing what is what.... I also wire up the data link, si reset, check engine light, and all that stuff as well. :)
Re: 24V Swap info
Postby ponycarman » Fri Sep 17, 2010 11:54 pm
Thats a really good deal to not have to go through all the hassles. I might get you to mod one when I get to do my swap.
EricT
Re: 24V Swap info
Postby EricT » Sat Sep 18, 2010 2:50 am
Just let me know. I'd be happy to get you all fixed up :)
EqualizedCustoms
Re: 24V Swap info
Postby EqualizedCustoms » Sat Sep 25, 2010 4:40 am
Eric hooked me up with my booster and harness. Said if i need help knowing what wires go where he'd come help me. :mrgreen: :mrgreen: :mrgreen:
EricT
Re: 24V Swap info
Postby EricT » Sun Sep 26, 2010 1:50 pm
I just said that so you'd leave.......
Im kidding. Of course I'd come help out.
Re: 24V Swap info
Postby Yoshi » Fri Oct 05, 2012 6:08 pm
apparently this thread is first when you search "E30 24v swap" w00t!
24V Swap info
Postby ten2doyle102 » Sat Oct 06, 2012 2:44 pm
Nice!!! I'll be using this info soon! M50 is on its way.
Re: 24V Swap info
Postby Nsquared97 » Sat Oct 06, 2012 4:06 pm
O'rly?
24V Swap info
Postby ten2doyle102 » Sat Oct 06, 2012 10:00 pm
Yep.... Just found out. Lol!
No, a friend of mine is selling me an m50 with trans, wiring, drive shaft, ecu and all the accessories for $400. I can't really turn that down... Lol!
More to come later
Re: 24V Swap info
Postby Nsquared97 » Sun Oct 07, 2012 3:23 am
Sweeeet! Can't wait to see this unfold.
