Turbo setup for $700-900?
Re: Turbo setup for $700-900?
Postby Yoshi » Tue May 12, 2015 5:40 pm
Well I mean, if you get a down pipe, you'll still have to weld up the rest of the exhaust. So why bother with a down pipe to begin with?
You don't weld? How'd you do all that body work on the chevy?
Postby M20_fever » Tue May 12, 2015 5:48 pm
Yeah I weld plenty. So did you just buy a flange to bolt to the turbo and work back from there? Just haven't seen much out there on down pipes and exhaust design. The CXracing kit just eliminated a lot of the work by supplying the down pipe with a flex end to bolt to the exhaust.
Postby Yoshi » Tue May 12, 2015 6:27 pm
Yep. Depends on the type of flange. I haven't done a V band that I haven't warped. But if it's a flat v band, you can just have it machined flat or take a belt sander to it. Most of the regular style cheap turbos have a simple bolt on thick ass flange you can weld to with a gasket to make sure it doesn't leak.
matthewreadephotography
Postby matthewreadephotography » Tue May 19, 2015 7:30 pm
Ive been away for awhile.... I thought you were supercharging it?
Postby ten2doyle102 » Tue May 19, 2015 7:33 pm
Sorry... Got a new phone and had tapatalk on it... Didn't realize I was logged in under a different username. Lol
Postby Yoshi » Wed May 20, 2015 11:51 am
Whore. He decided turbos because the SC was too much work lol
Postby ten2doyle102 » Wed May 20, 2015 4:50 pm
I see. This is why I shouldn't leave for so damned long.... I have a nice new phone now so staying connected should be easier. :)
Postby M20_fever » Sun May 24, 2015 8:33 pm
Yeah, the SC will be a ton of fab work I honestly don't have time for these days...I think with the right settings in MS I should be able to eliminate the issues I was concerned about with the turbo.
Postby ten2doyle102 » Mon May 25, 2015 5:19 am
Sweet man. Can't wait to see how this all progresses. Your car was awesome in its current form so a turbo should make it pretty awesome. :)
Postby M20_fever » Tue May 26, 2015 1:29 pm
yeah, a couple hundred more HP should make it pretty fun, lol.
Corben really came through for me, like big time! I'll get some pics later but so far it looks like he sent me a turbo (needs assembly and probably rebuild), MBC, a boost gauge, a bunch of vacuum line, and some misc hardware and clamps and such. Still sorting through the box, but it looks like all I really need to source at this point is a manifold and oil lines!
Postby ten2doyle102 » Wed May 27, 2015 8:47 pm
Badass. Just gonna go with a cheapy mani? or something top of the line?
Postby M20_fever » Mon Jun 01, 2015 3:43 am
Cheapo ebay mani for now, should be fine to get me the power I'm shooting for.
Postby Ryki » Fri Jun 12, 2015 7:11 am
Hurrah for turbo fun! Looking forward to progress as you get into things :D
Postby M20_fever » Fri Jun 12, 2015 2:12 pm
Me too man, looking at rebuild kits for that turbo now! I'll try and get some pics up this weekend.
