M5x Options for Autocross/Track
Re: M5x Options for Autocross/Track
Postby Yoshi » Mon Jun 29, 2015 11:47 am
hand job?
Postby 87e30 » Wed Jul 01, 2015 11:27 pm
Yoshi wrote:hand job?
From a lil Colombian? Sure, assuming it's a female. :-D
Postby blasphemy101 » Fri Jul 03, 2015 3:38 am
Okay, so I found an engine! We've gotten the hard part taken care of - the engine is out of the car. We ran into a little hang up, though. We can't figure out how to get the engine harness out of the car. It looks like part of the harness runs into the fuse box (which makes sense, I guess). I haven't found anything online that talks about how to remove that portion from the fuse box, and I haven't seen anyone bring the whole e30 fuse box over. The guy I'm getting it all from says he thinks I need the fuse box, but I'm not so sure.
Postby Ryki » Fri Jul 03, 2015 4:31 am
You remove the connector from the ECU and feed it through the grommet, not the easiest thing in the world if I remember right.
Postby blasphemy101 » Fri Jul 03, 2015 11:23 am
Wrong side of the harness... I'm talking about the x20 side of the e36 harness. Sorry, I should have been more clear
Postby Yoshi » Fri Jul 03, 2015 1:29 pm
got pix? Why not just disconnect the X20 and fuck the rest of the harness? You don't need it.
Postby blasphemy101 » Fri Jul 03, 2015 3:00 pm
I'm an idiot. There are 3 relays attached to the side of the fuse box. I don't know if they are used in the swap. If we had just opened the lid of the fuse box we would have seen them and saved ourselves another trip over. The motor/trans are in my driveway. 24V build thread to come.
Postby Yoshi » Fri Jul 03, 2015 6:44 pm
Those relays are the same as in E30s iirc. They are the fuel pump/o2/main relays. It should be attached to the main harness.
yoshi demands pix!
Postby Ryki » Fri Jul 03, 2015 9:24 pm
Question, what kind of bracket moving does changing to a M5x engine do to you?
Postby Yoshi » Sat Jul 04, 2015 3:23 am
Can you be more specific? The relay mounting? I just put it on the factory E30 one. Looks factory!
Postby Ryki » Sat Jul 04, 2015 5:25 am
Those relays are for fuel pump, abs I think and something else, why not reuse em?
Return to “Engine”
