I bought it for $500 .. What did I bought ?
...pizza !
- ten2doyle102
- I <3 E30's
Re: I bought it for $500 .. What did I bought ?
Definitely a sweet pick up for $500 bucks!!!
. I am uber jelly!
Fix the rust and drive the crap outta it?!
- M20_fever
- Größter Vorsitzender
Probably just an expensive valve cover. That valve cover is worth almost as much as what you paid for the car. I assume your other e30 has a full interior? Gutting an e30 can make a big difference in performance. Did you do the head gasket yet? In a fantasy there would be a 24v RD head hiding under that cover, but highly unlikely. You can open up the ECU and see if it's got a chip in it, that makes a huge seat of the pants difference to. What RPM does it hit the rev limiter?
Use our VIN decoder thread to see what it came from the factory with. Either way, for $500 you stole it.
