M20 types and part compatibility
Re: M20 types and part compatibility
Postby ten2doyle102 » Fri Mar 20, 2009 4:14 pm
BMWIS wrote:
M20_fever wrote:
BMWIS wrote:A couple other questions. What's the max overbore that one can do to an M20 B25. It seems people avoid overboring. Is that just to save money. I'm thinking of a .040 overbore.
86mm but thats pushing it.
I'm dumb. How much is 86mm over standard bore in "'s
And man oh man I was hoping someone would comment on the Euro motors.
Conversion: 1in = 25.4mm
86mm = 3.3858" approx.
84mm (stock) = 3.3071" approx.
So that would be about .0787" bigger.
As for the euro motors, sorry, I don't know much on them!
Trent
Postby Trent » Mon Mar 23, 2009 10:33 am
Ok i so didnt know that the m20b5 had a smaller stroke than the m20b23.
Just curious but im not too sure did you guys in the us get the 323
cheers for the info
Postby Court M3 » Mon Mar 23, 2009 12:55 pm
We didn't get the 323i. Some people did import them though.
Trent
Postby Trent » Tue Mar 24, 2009 11:29 am
cheers thats what i thought it was only a euro model.
BMWIS
Postby BMWIS » Wed Mar 25, 2009 2:49 pm
Ok here is an M20 question.
Is the Euro 885 325i head the same as the US 885 head?
Postby ten2doyle102 » Wed Mar 25, 2009 3:04 pm
RealOEM gives the same part numbers. I would guess them to be the same since they'd have the same casting numbers.
Postby M20_fever » Wed Mar 25, 2009 3:07 pm
yes, all 885 heads are the same.
BMWIS
Postby BMWIS » Wed Mar 25, 2009 7:36 pm
Who sells BMW pistons?
Tchao
Postby Tchao » Wed Mar 25, 2009 8:00 pm
Try eBay.
I got a set of brand new Mahle pistons with OE Malhe rings for $125.
E30 M50nv
BMWIS
Postby BMWIS » Wed Mar 25, 2009 8:58 pm
Needs to be overbore. .040
Postby M20_fever » Wed Mar 25, 2009 9:10 pm
unless you go to a factory overbore i.e. 84.5mm you will need custom pistons.
Tchao
Postby Tchao » Wed Mar 25, 2009 9:24 pm
Most replacement pistons are overbore. Rarely do you find pistons of the original bore. Which you shoudn't anyways.
E30 M50nv
Orac
Postby Orac » Tue Jun 23, 2009 8:55 pm
320is did not have a m20b20. It had an S14.
320i had a m20b20. The m20b20 used the 731 head.
Postby M20_fever » Tue Jun 23, 2009 9:03 pm
Didn't only South Africa get the s14 powered 320is? IIRC it had factory 5 lug as well.
BimmerJake
Postby BimmerJake » Tue Jun 23, 2009 9:04 pm
that was my understanding, i'm pretty sure everywhere else what the b20.
Douglas Adams wrote:The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair.
