How to: Cylinder Head Gasket Change
imagine-02
Re: How to: Cylinder Head Gasket Change
Postby imagine-02 » Thu Dec 17, 2009 2:52 am
What head set did you go with?
Thanks for the write up!
STAY IN SCHOOL! Your writing is a direct correlation to your intelligence.
-95' Eagle Talon tsi awd
-88' BMW 325 Super-ETA
Postby ten2doyle102 » Thu Dec 17, 2009 3:06 pm
I kinda pieced the kit together.
This is what a used
Goetze Head Gasket <-- got it from rmeuropean
BMW OEM Head bolts
Victor Reinz Exhaust gaskets (only cause it just an exhaust gasket...)
BMW OEM cam seal and O-ring
BMW OEM Rocker Shaft plugs - Highly reccommend buying these from there because aftermarket ones tend to be a bit smaller
Victor Reinz Intake Gaskets - Just cause they seemed to do ok on my red car...
BMW OEM throttle body gasket
Contitech Timing belt
Water pump - I can't remember that brand
BMW OEM t-stat w/ gasket
BMW OEM T-stat housing gasket
All new Exhaust studs
If I think of anymore stuff, I'll add it in!
imagine-02
Postby imagine-02 » Tue Jan 05, 2010 11:43 pm
I got my head gasket set, head bolts, and head back from the machine shop. Will be doing the I head swap within a couple days. Hopefully your write up helps! :D
Postby ten2doyle102 » Wed Jan 06, 2010 12:47 am
Let me know if there is anything that really needs to be looked at. I tried my best to make sure that write up caught most of everything. Do you have a bentley to use as well? I'd have that on had as well.
My biggest piece of advice is to bag the bolts in seperate bags so that you can mark where they go. I forgot to do this as I was disassembling so reassembly was a pain..
imagine-02
Postby imagine-02 » Wed Jan 06, 2010 11:27 pm
No Bentley. Should the local parts stores have them? (oreilly, napa, advanced, checker,...)
Postby M20_fever » Wed Jan 06, 2010 11:58 pm
nope, if your lucky a local book store like Boarders might have one in stock but more than likely you will need to order it online.
imagine-02
Postby imagine-02 » Thu Jan 07, 2010 5:39 pm
Know of anywhere to get it cheaper than this?
http://www.turnermotorsport.com/html/de ... CT_ID=B390
Postby M20_fever » Thu Jan 07, 2010 5:44 pm
meh, Amazon has some used ones for $32, but thats about normal for it. It's well worth the investment.
Postby ten2doyle102 » Thu Jan 07, 2010 5:51 pm
Very much worht IMO. You'll use it alot if you do alot of work on the car. Its got everything in there for the most part that you'd really need to know.
Postby M20_fever » Thu Jan 07, 2010 6:11 pm
I used mine all the time for the first year I had an e30, but I can honestly say I haven't opened mine in a year. I still use it now and then for torque specs and such though.
bataangpinoy
Postby bataangpinoy » Mon Jan 11, 2010 6:14 pm
did it this weekend, total 6 hours(first time, i work a lil slow :? )
Postby ten2doyle102 » Mon Jan 11, 2010 7:17 pm
Yeah, If you work on it, you can do it in an after noon. I just did it little by little.
kevinlvy
Postby kevinlvy » Tue Jan 25, 2011 12:07 am
nice compilation of photos and information there.
thanks i might be busy tomorrow since there have been oil leaks the other night and my friend told me to check the engine since he has extra cylinder head bolt and valve cover gasket set i would be in good hands tom.
nomade30
Postby nomade30 » Tue Feb 01, 2011 7:21 am
The bentley is by far the best tool I have bought for any car. It gives you the info when you need it, but to be honest you start to remember the torque specs after doing something a few times.
Just to add in if any of you need head studs, just let me know, it's a great time to do it while changing your head gasket.
Postby ten2doyle102 » Tue Feb 01, 2011 1:49 pm
That's what I used the first time I did a head gasket. I found that it was a bit confusing from time to time though.
