Things to change when you first get an E30 (M20)
siazul
Re: Things to change when you first get an E30 (M20)
Postby siazul » Tue Mar 08, 2011 2:14 am
I ordered them without first "choosing my vehicle" and once I did it like that, it says they dont fit?
siazul
Postby siazul » Thu Mar 10, 2011 3:38 pm
got my wires yesterday afternoon
Postby 87e30 » Thu Mar 10, 2011 5:18 pm
siazul wrote:got my wires yesterday afternoon
Do they fit?
siazul
Postby siazul » Thu Mar 10, 2011 6:03 pm
Its Raining, but Im at work, gonna do some work on the car on Saturday so Ill try then, the receipt lists the 325i so I should be good, they look correct.
glucklich21
Postby glucklich21 » Tue Mar 29, 2011 6:15 pm
Lets add fuel lines!
Two friend's E30s have had cracked fuel lines, and the second one had a small fire because of it.
So yeah....
Postby M20_fever » Tue Mar 29, 2011 6:35 pm
May be a good thing to check when you buy any car, but I wouldn't say they are things that should be changed any time you buy an e30. I've owned 3 e30s and only 1 of them needed a new fuel line.
logantv
Postby logantv » Wed Jun 01, 2011 9:46 pm
How did those wires work out? I see in the description that there's no pulse generator...
siazul
Postby siazul » Thu Jun 02, 2011 12:52 am
Wires worked fine, pulse generator? what kind of pulse lol, there was a wire going from a connection near the intake mani to one of the wires on the old wires but car runs just fine without it.
b27e30
Postby b27e30 » Tue Jan 29, 2013 7:38 pm
I haven't done anything to mine. Besides oil, air, and fuel filter. Fuel filter came out clean. the timing belt had also been done in Jan 2012 with receipt from BMW of Fairfax. No leaks. And went straight to modding.
Car does need shifter bushings, probably cam seal, and cleaned injectors to need nothing. I got lucky.
H&R OE Sport Springs - Bilstein HD's - Kosei K1's ET27 - Toyo R888 - ZHP 5spd knob - Strut bar - Street Tuned Chip - E30 M3 Offset Bushings - Colgan bra - P-car daily
Postby M20_fever » Tue Jan 29, 2013 9:03 pm
Sounds like a well maintained car, but I would bey money none of the suspension bushings have ever been replaced. Also trans/engine mounts. The brakes have probably not been bled, let alone flushed in decadeds, etc...There is always maintenance to be done on a 20 year old BMW, lol.
b27e30
Postby b27e30 » Wed Jan 30, 2013 12:11 am
M20_fever wrote:Sounds like a well maintained car, but I would bey money none of the suspension bushings have ever been replaced. Also trans/engine mounts. The brakes have probably not been bled, let alone flushed in decadeds, etc...There is always maintenance to be done on a 20 year old BMW, lol.
lol, true I took care of all the items you just mentioned. This car sold for 8k in 2008 with 96k miles from concord motorsports. Suspension bushings are in great condition. The rear subframe is not resting on the washers lol. I put about 200-300 into what the car really needed the rest was just play money. I'm in about 1500-2000. That's with a spare set of wheels and tires for autox. Yoshi has seen it. took it to him shortly after I bought it.
Postby Yoshi » Wed Jan 30, 2013 12:43 pm
damn bmw drivers. parking all close and shit.
zoeyku
Postby zoeyku » Thu Oct 31, 2013 3:50 am
I didnt do the camshaft seal when I did my timing belt.
Postby Yoshi » Thu Oct 31, 2013 12:09 pm
I mean, if it ain't leaking... you're fine.
Postby M20_fever » Thu Oct 31, 2013 12:52 pm
If its not leaking its not a must, but I do it anyway because I don't want to pull it all apart again when it starts leaking.
