Yoshi's Brake Caliper rebuild
Postby Yoshi » Thu Jan 20, 2011 10:10 pm
Let me know how I did. I reformatted my computer so I had to use the new windows movie maker. Which is... ok. I also rushed to put together the video. I need to get better at taking video.
Re: Yoshi's Brake Caliper rebuild
Postby M20_fever » Thu Jan 20, 2011 11:58 pm
Looks good! I'm not getting any sound, may be my computer though. I had to send my good machine for some warranty work so I'm on my backup machine which is pretty old.
Postby Yoshi » Fri Jan 21, 2011 1:41 am
I has sound when I view it from my phone. I'm driving to nh rite meow tho
Postby M20_fever » Fri Jan 21, 2011 10:04 pm
I'm sure its this machine.
Postby Yoshi » Sat Jan 22, 2011 4:47 pm
Well find a good one and let me know how it is.
Postby pr0craztinazn » Sat Jan 22, 2011 11:02 pm
Sound works. Turned out better than you said it did!
Postby Yoshi » Sun Jan 23, 2011 1:21 am
Eh tossed it together real quick. Eventually I want to do tv show quality stuff. Maybe not just how tos but like a mini series
toointoxicated62
Postby toointoxicated62 » Tue Jan 25, 2011 1:36 am
fairly good video. But i recommend not using anti-seize.
Dip the square cut seal in brake fluid, install it, then dip the piston and install it. The brake fluid lubs everything up.
Do not sand or score the piston. If you sand it, it will rust over time when water gets into the brake fluid. Any score marks or roughness will wreck the square cut seal and it will just piss out fluid. The caliper body isn't that important.
To clean it out caliper, either use brake cleaner ad go to town or get a gallon of gas a metal tub and put the caliper bodies in them. Leave them over night. The gas will degrease and get all the crap out. Then use compressed air to dry them out.
Also when using anti-seize on the slider pins make sure you put the cap on. If you don't dirty/sand and other crap will get caught in the anti-seize and end up seizing. Ask me how i know ;)
Delanoso
Postby Delanoso » Thu Jun 13, 2013 12:13 pm
So, I feel like a jackass newb. How the hell do you get the pistons out without wrecking them? I've managed to contain the damage to just the outer end that contacts the brake pad but I feel like I'm missing a trick here.
Postby M20_fever » Thu Jun 13, 2013 12:30 pm
put a piece of wood in the caliper and use shop air to blow the piston out. WEAR EYE PROTECTION, brake fluid will spray out.
Postby Yoshi » Thu Jun 13, 2013 1:57 pm
what he said. I'm pretty strong so I could actually get mine out by hand. Air is much better on the body
Delanoso
Postby Delanoso » Thu Jun 13, 2013 4:29 pm
That's what I was afraid of.
Yoshi, I'm reporting you to the FCC your for false advertising in your video. -yuush-
Meh, I'll figure it out. I don't have a compressor but I know some people who do.
Postby Yoshi » Thu Jun 13, 2013 4:32 pm
It was hard but i got mine out by hand. *shrugs* keep at it?
Postby 87e30 » Thu Jun 13, 2013 5:28 pm
Yoshi wrote:It was hard but i got mine out by hand. *shrugs* keep at it?
Out of context quote of the day! -yuush-
Postby M20_fever » Thu Jun 13, 2013 6:16 pm
^^^win
