M20_Fever's RX-7 caliper rebuild
Motion
Re: M20_Fever's RX-7 caliper rebuild
Postby Motion » Mon Nov 17, 2014 5:28 pm
Many thanks for the info!! Cheers !
Postby M20_fever » Mon Nov 17, 2014 8:23 pm
I bought mine with the rest of the kit from Matt (ten2Doyl102) a while ago, but I don't think he still sells them.
Motion
Postby Motion » Thu Nov 20, 2014 3:43 am
I purchase rx7 caliper from rockauto.com part numer: FRC10384
72$ each caliper freshly rebuilt
got the fitting from: http://www.parcelparts.com/metric-inver ... ers-pkg-5/
Some braided brake hose from ECS tuning for 79$
750il 1990 Master cylinder from rock auto ... Wholesales close out ... got it for 58$
Not bad at all for all those part !!
Postby M20_fever » Thu Nov 20, 2014 2:25 pm
Why are you swapping to the 750iL master?
Postby 87e30 » Thu Nov 20, 2014 3:39 pm
I was wondering that too.
Motion
Postby Motion » Mon Nov 24, 2014 2:36 am
Because the MC from my 325is 1987 is 21mm and upgrading to the 750iL upgrade it to 25MM
Direct bolt on to the brake booster.
Brake pedal will be firmer and pedal travel won't be affected by the over sized caliper.
The only concer I have regards those fitting:
when the brake hose male end screw into the female part of the fitting ... only 1.5 thread is used before it's tight... I don't feel it secure for severe track use ...
My brake hose are from ECS tuning.
Then I was looking at the caliper and I will test the brake hose directly into the FD caliper without the fitting. It should fit correctly
also, take a look at this topic: http://www.e30tech.com/forum/showthread.php?t=83511
Postby M20_fever » Mon Nov 24, 2014 4:37 pm
You don't need to upgrade the master. I heavily track my car and run the stock master, pedal feel is excellent. The ECS lines should be the same as any other stainless lines, make sure you have the right flair on the right side. Mine fully engaged.
Postby 87e30 » Tue Dec 02, 2014 1:28 pm
Is there a down side to using a 750 master? I've had pretty bad luck with stock ones in my car. The current one is holding up for now, but if it goes again I'll be looking into other options.
Postby M20_fever » Tue Dec 02, 2014 6:38 pm
Only down side would be if you don't like the harder pedal feel I suppose. I still run ABS so I didn't need to worry about pedal feel. What issues have you had with stock units? I would think an OE new master would be reliable. My buddy had his go out at the track and we ran to the local parts store and grabbed a cheapo brand and it held up find for the rest of the season.
Postby 87e30 » Tue Dec 02, 2014 7:44 pm
My problem was just with junkyard units that never worked right. A new one would cost me half of what I paid for the car! lol
Postby M20_fever » Wed Dec 03, 2014 4:37 pm
Some things you don't buy used. ;-)
Postby 87e30 » Wed Dec 03, 2014 4:55 pm
Like condoms?
Postby M20_fever » Thu Dec 04, 2014 4:49 am
nah, condoms are fine. How else will you know if they work? Let someone else test em' first.
Postby 87e30 » Thu Dec 04, 2014 4:07 pm
I hope you at least rinse them out first.
Postby Yoshi » Thu Dec 04, 2014 6:06 pm
rinse? Just turn them inside out.
