Rear Brake Conversion - RX7?
Re: Rear Brake Conversion - RX7?
Post by ten2doyle102 » Wed Jun 13, 2012 1:09 pm
Yes. I am not very good at figuring all that out. I would assume it would.
Post by Nsquared97 » Wed Jun 13, 2012 3:09 pm
ten2doyle102 wrote:Also, does anyone know... will a conversion like this bump me to DSP or SM? Right now the car is setup for STX/R so I was wondering what a BBK would do to me.
Right now you'd be STX, E30 isn't allowed in STR ;)
But I'm not sure where this would kick you, pretty sure BBK's aren't allowed in STX. I'll have to look it up later, don't have time right now.
Post by ten2doyle102 » Wed Jun 13, 2012 6:27 pm
Hmm....I thought it would be in STR. verid!
Post by ten2doyle102 » Thu Jun 14, 2012 1:56 pm
Alright,
I ordered up a set of four line adapters for the RX7 calipers from 2002manaic on R3v.... Also, I am gonna try the calipers on the rear just for fun. My friend works at parts warehouse and is hooking me up with a mini cooper front rotor to play with. It was $12 so I figure it would be fun to play with. They are 275mm rotors and vented so it should be pretty sweet. Only issue is gonna be the parking brake which I'll be removing away.
I don't know, I am just gonna give it a shot for shits and giggles.
So, if all goes well, I should have be able to do RX7 calipers all the way around for like $150-$200. LOL!
Post by M20_fever » Thu Jun 14, 2012 2:26 pm
So stoked! I foresee more BPP parts on my car in the near future!
Post by ten2doyle102 » Thu Jun 14, 2012 2:30 pm
Probably.. lol!
Also... forgot to include brake pads in that.... so it will be a bit more.. :) lol!
Post by M20_fever » Thu Jun 14, 2012 2:37 pm
How nice will it be to be able to swap the front pads to the rear and just replace front pads though?
Post by ten2doyle102 » Thu Jun 14, 2012 3:18 pm
Very nice! I am super excited to try this out. My fab shop is gonna start on the brackets today I think. :) For the fronts only now. I need to measure up the rears..
Post by Nsquared97 » Fri Jun 15, 2012 4:15 pm
ten2doyle102 wrote:Hmm....I thought it would be in STR. verid!
Haha nope, STR is limited to a select few cars. Plus your car isn't a roadster is it? :P (Street Touring Roadster)
But it does look like your allowed to do BBK's for STX, so have at it!
Post by ten2doyle102 » Fri Jun 15, 2012 4:53 pm
Oh... lol! I thought it was STR (Street Touring Rear) and STF (Street Touring Front)
I am working on it tonight!!! :)
Post by Nsquared97 » Fri Jun 15, 2012 7:53 pm
Ahh nope.
ST(FWD)
ST(Compact)
ST(Sport)
ST(Roadster)
ST(Xtreme)
ST(Ultra)
Also just to note, you are supposed to have a working E-brake according to the rules. Not that it matters or anyone would ever care, but I figured it would be good to know anyway.
Post by ten2doyle102 » Fri Jun 15, 2012 10:00 pm
Well... My brake hasn't worked ever... Lol!
Post by ten2doyle102 » Sat Jun 16, 2012 4:45 am
Alright, so a little update for you guys.
So here is the first type of rotor setup. I got a 2002 Mini Cooper Front rotor and it looks like everything will fit out ok with a small issue.
Anyway, heres a pic the old rotor and the new one.
IMG_5451 by ten2doyle102, on Flickr
And here it is mounted.
Looks good!
IMG_5452 by ten2doyle102, on Flickr
IMG_5453 by ten2doyle102, on Flickr
Back side....
IMG_5455 by ten2doyle102, on Flickr
However, we got a small problem....
IMG_5454 by ten2doyle102, on Flickr
I am looking into a special version of the cooper rotors that are 294mm so this hopefully won't be an issue. Lucky ,e though, it seems like they will clear my 15's!
Post by ten2doyle102 » Wed Jun 20, 2012 3:01 pm
So I did a bit more work on this and drew this up. The caliper is not 100% accurate, but it's close. I made this purely for mock-up purposes, but it shows what I am looking at doing.
Right now, drawn is a Stock FC RX7 Caliper with a 1997 Acura NSX rotor. I will have to redrill the rotor to fit a 4x100 as well. I did plenty of research on this and found that it's a common practice on EG and EK civics where they use a 300mm RSX rotor and drill it to 4x100 as well. Many use that setup for racing so I don't see why I couldn't use it on a e30... ;) Also, looking at it, not sure how well the FC caliper will fit a 300mm rotor....won't really know till I get it in there. I have a rotor on order now though.
Here, take a look:
BRAKES by ten2doyle102, on Flickr
Post by ponycarman » Wed Jun 20, 2012 3:35 pm
Cool! Are the rotors your using vented? Do you know an approximate cost of doing this?
