Clutch Help
Clutch Help
I'm working on 86 325 and I'm wondering what style clutch this is? I have never seen one like this and I'm wondering if this will hold up to a turbo set up
- Attachments
- photo[1] (2).jpg (108.29 KiB) Viewed 1924 times
- Nsquared97
- I <3 E30's
Re: Clutch Help
That's the flywheel, not the clutch correct? I'm guessing that's a dual mass one, mines a single mass so I have never dealt with/seen a dula mass in person.
Re: Clutch Help
Yes it is the Flywheel not the clutch. Is there an advantage to the dual mass one than the single And will It hold up to a turbo setupNsquared97 wrote:That's the flywheel, not the clutch correct? I'm guessing that's a dual mass one, mines a single mass so I have never dealt with/seen a dula mass in person.
- Nsquared97
- I <3 E30's
Re: Clutch Help
From what I have seen, most people tend to prefer the single mass. I haven't done much research on the subject at all though, Yoshi and Tony should be able to chime in on this. No idea about how it would hold up to a turbo setup.jp 84 wrote:Yes it is the Flywheel not the clutch. Is there an advantage to the dual mass one than the single And will It hold up to a turbo setupNsquared97 wrote:That's the flywheel, not the clutch correct? I'm guessing that's a dual mass one, mines a single mass so I have never dealt with/seen a dula mass in person.
- Yoshi
- Site Admin
- Contact:
Re: Clutch Help
That is an eta dual mass. It makes shifting with harsher clutches easier. single mass are lighter and therefore help the engine rev up (and down) faster.
- M20_fever
- Größter Vorsitzender
Re: Clutch Help
It will hold up fine to boosted applications, but it holds revs a lot longer than a single mass, and you won't get that crisp low end throttle response you will with a single mass.
