Axles
-LSD-
Axles
Post by -LSD- » Mon Jan 07, 2013 8:36 am
Hey guys, havent wrote in a while... i have a stupid question about axles
Does anyone have issues with axles? i keep getting headaches with a driver side axle.
its a third axle now. first two backed out all 6 bolts bent them and stripped them out ( used locktite both times) smh.
I honestly dont know what to think anymore. Right side is still original 20+ years old axle. but driver side just dont want to stay in my car.
Anyone ever ran into this issue, any info will be appreciated =)
Alex K.
Re: Axles
Post by Yoshi » Mon Jan 07, 2013 1:01 pm
did you use a small case diff on accident? Are you super low?
I converted to E36 diff bolts and haven't had a problem. I converted mainly for the torx instead of allen heads but they seem to work great.
Re: Axles
Post by M20_fever » Mon Jan 07, 2013 10:08 pm
what color loctite are you using?
-LSD-
Re: Axles
Post by -LSD- » Sat Jan 12, 2013 3:27 am
yeah i am using small case on accident =) car is not super low. its lowered but i also have a raised subframe bushings so axles are perfectly straight. thats what bogging me.
I did have a med case originaly, after bolts stripped out i couldnt repair the threads on a flange so i got a small case from my buddy, who was running it in his m50 e30.
RED locktite =)
i honestly dont know what to think at this point =) just bought new axle + all new hardware form bmw...intalling this weekend...
Alex K.
Re: Axles
Post by M20_fever » Sat Jan 12, 2013 4:13 am
might be wise to chase the threads in the case before trying to bolt it all back up.
Re: Axles
Post by Yoshi » Sat Jan 12, 2013 1:26 pm
small case diffs will always pull the axle out. you need axles from a small case IIRC.
-LSD-
Re: Axles
Post by -LSD- » Tue Jan 15, 2013 2:33 am
i did chase threads and all that jazz....came out to be pretty good.
When i was about to drop small case in my car, i put it next to my medium case diff, the distance from a flange to flange looked identical, otherwise i wouldnt use it in a first place. Plus first broken axle was with med case...and... passenger side axle is still original...so im kind of confused on this one.
Anyways, i put everything back last night, track event coming up, will see whats gonna happen =)
Alex K.
Re: Axles
Post by Ryki » Tue Jan 15, 2013 2:52 am
I hope everything works out well!!!
Re: Axles
Post by M20_fever » Thu Jan 17, 2013 3:30 pm
keep us posted.
