dual mass clutch
jp 84
dual mass clutch
Postby jp 84 » Wed Jan 23, 2013 4:27 am
i have a dual mass clutch fly wheel and i want to change it to a signal mass fly wheel is it possible gust to bolt a new single mass one on or is there more than that?
Re: dual mass clutch
Postby M20_fever » Wed Jan 23, 2013 4:50 am
Thats it, just make sure you get the right clutch for the flywheel.
Postby Yoshi » Wed Jan 23, 2013 12:47 pm
clutch must match flywheel. I think the rest can stay the same assuming it's from the same motor. EG I'm not sure an M42 dual mass is swappable with an M20 single mass without at least a throw out bearing.
jp 84
Postby jp 84 » Wed Jan 23, 2013 9:49 pm
Yoshi wrote:clutch must match flywheel. I think the rest can stay the same assuming it's from the same motor. EG I'm not sure an M42 dual mass is swappable with an M20 single mass without at least a throw out bearing.
do u know where i could get a fly wheel for a 1987 325 with a 2.7l. i have looked up some but i did not find any that where a single mass
Postby M20_fever » Thu Jan 24, 2013 2:22 am
Any 325i flywheel '87-'91 ('92 &'93 convertibles too) will be single mass, the 'e' cars got the dual mass.
Postby Yoshi » Thu Jan 24, 2013 1:50 pm
most 'e' models got a dual mass. I've found some with thick ass singles.
jp 84
Postby jp 84 » Sat Jan 26, 2013 3:34 am
Yoshi wrote:most 'e' models got a dual mass. I've found some with thick ass singles.
i know that the dual mass ones are thick and if i where to get a single mass flywheel out of a 325i would the thinner one work? i am thinking that the throw out baring would not have enough throw.
Postby M20_fever » Sat Jan 26, 2013 5:40 am
You need to match the clutch kit to the flywheel, so when you swap to a single mass you need to get the 'i' clutch kit.
