Yoshi and viet's Auto to Manual Swap Guide
insilico
Re: Yoshi and viet's Auto to Manual Swap Guide
Postby insilico » Mon Jul 01, 2013 7:09 pm
Kidding...kind of. Took six hours to just remove the driveline, power converter/tranny, pressureplate, clutch and flywheel. Didn't exactly get on with the removal of the Auto out of my 91.
I guess I should make a thread about all this. Took a handful of pics.
91 ix Coupe
90 ix Saloon
96 Tacoma 4x4
Postby Yoshi » Mon Jul 01, 2013 10:22 pm
You should :)
Postby Ryki » Tue Jul 02, 2013 7:49 am
^times two!!
Postby ten2doyle102 » Thu Apr 17, 2014 10:32 pm
Hey, got a quick question for y'all...
Is there any reason why you would need to swap steering columns from a 5spd car to the Auto car??? I would think everything should swap over, no?
Postby Yoshi » Thu Apr 17, 2014 11:18 pm
The whole column? No. Not unless you want to get a longer steering shaft for a single U joint rack... but no reason.
Postby ten2doyle102 » Fri Apr 18, 2014 4:50 am
hmmm....Would it matter you think if the 5speed swap was from a 1988 going into a 1990? Early to late? I don't know... my buddy insists its different.
Postby Yoshi » Fri Apr 18, 2014 11:05 am
Oh they are very different. but you don't need to swap them lol. The 1990 has a part that mounts to a new section of the steering column... support. not the steering column. I just left those bolts out because the 4 against the fire wall and the same 2 should be accessible up top. More than enough.
Summation:
column is different
column support is different
probably not all holes are lined up
6 out of 8 or 10 bolts ain't bad.
Postby ten2doyle102 » Sat Apr 19, 2014 4:26 am
OK. Sounds good dude. I just hadn't heard of that before. I am not sure what his plan is. Its a customers car so they gotta talk it over. They were thinking about swapping the steering columns to.
Postby Yoshi » Sat Apr 19, 2014 12:50 pm
Is it air bag?
