Manual Transmission and Rear Differential fluid changing
Re: Manual Transmission and Rear Differential fluid changing
Postby M20_fever » Sun Mar 29, 2009 5:43 pm
yep, the whole facility is DIY except the tire changing, they have techs do that for you. It's awsome, I've been trying to get a job on base for some time now, then I can use it without having someone bring me as a guest.
3LOW M3
Postby 3LOW M3 » Mon Mar 30, 2009 12:43 am
on base?
Postby ten2doyle102 » Mon Mar 30, 2009 3:36 am
That's really cool! Great idea! Its too bad they don't have anything like that around here because there have more than on one occansion that would have come in handy!
Postby M20_fever » Tue Mar 31, 2009 2:02 am
yes, it's on base. You have to be military to use it, but I have friends. :wink:
Tchao
Postby Tchao » Fri Apr 03, 2009 5:48 am
An easy way to fill a diff if you dont have a pump is this:
Took no more then a min before it was full.
I guess you can apply this to the trans also.
E30 M50nv
Postby M20_fever » Fri Apr 03, 2009 4:45 pm
other than needing 3 hands to work it, not a bad idea. could likely hook it up in similar fashion to an air compressor too.
Postby Yoshi » Fri Apr 03, 2009 5:55 pm
M20_fever wrote:other than needing 3 hands to work it, not a bad idea. could likely hook it up in similar fashion to an air compressor too.
:lol: I'm 12
Postby ten2doyle102 » Fri Apr 03, 2009 5:59 pm
LOL!!!! dirty dirty!! :)
Tchao
Postby Tchao » Fri Apr 03, 2009 9:34 pm
Only need two hands...Good thing because Jesus only gave me two.
An air-compressor would be best. Im too poor to have one though. :?
E30 M50nv
