Yoshi's Differential Rebuild/mod (pre)write up
AntiSpam:No
Re: Yoshi's Differential Rebuild/mod (pre)write up
Post by M20_fever » Sat May 01, 2010 5:03 am
awesome video man, much improvement.
AntiSpam:No
Post by Yoshi » Sat May 01, 2010 12:31 pm
Thanks. I can do much much better. I need to get another copy of adobe premiere. movie maker sucks. I'm really bad at talking into the camera too. Sigh...
AntiSpam:No
Post by M20_fever » Sat May 01, 2010 1:42 pm
Nah, seemed fine to me. You need a couple cameras so you can change up the shots in editing. :)
AntiSpam:No
Post by Yoshi » Sat May 01, 2010 2:17 pm
maybe ill just move the 1 around lol.
AntiSpam:No
Post by M20_fever » Sun May 02, 2010 7:28 pm
you'll have your own DIY tv show in no time!
AntiSpam:No
Post by Yoshi » Mon May 03, 2010 12:07 pm
I started one for the holset rebuild but I fucked it up. Sooo it's going to a shop.
AntiSpam:No
Post by M20_fever » Tue May 04, 2010 2:46 am
haha, put together a blooper reel, it would be epic!
samiam3356
AntiSpam:No
Post by samiam3356 » Thu Sep 02, 2010 3:52 pm
Nice work Yoshi! This explains some of the questions I had on rebuilding my diff. I think it would have made much more sense if I had been the one to pull it apart but it came disassembled. Setting lash to me at the moment means making sure the gears are the proper space apart. However, I have no idea how to set it. I'm assuming on the install part it will make sense to me.
BTW when you said to look at your Youtube video for this I thought you were fucking with me. I looked for a while on youtube but couldn't find them. Just now am I seeing it! lol
Thanks for the write up,
Sam
┌∩┐(✖_✖)┌∩┐
AntiSpam:No
Post by Yoshi » Thu Sep 02, 2010 4:27 pm
If the diff has the plates in a way you know which side is which, lash shouldn't be an issue. You'll have to do the paint method or get an actual gauge otherwise. Lash is side to side distance and pinion depth is forward to backward. Pinion depth is factory set unless you redo the pinion bearing. So assuming the pinion gear is untouched, you just have lash to play with if at all.
samiam3356
AntiSpam:No
Post by samiam3356 » Thu Sep 02, 2010 5:05 pm
Thanks man, you need to set up a donation section. Maybe get stickers or something. I like doing all my own work when I can and appreciate information like this.
┌∩┐(✖_✖)┌∩┐
AntiSpam:No
Post by Yoshi » Thu Sep 02, 2010 5:09 pm
I'm too busy/lazy for stickers and shit lol. Plus I don't want money. so I'm good :)
AntiSpam:No
Post by M20_fever » Thu Sep 02, 2010 9:34 pm
samiam3356 wrote:Thanks man, you need to set up a donation section. Maybe get stickers or something. I like doing all my own work when I can and appreciate information like this.
http://e30performance.info/viewtopic.php?f=27&t=484 :wink:
samiam3356
AntiSpam:No
Post by samiam3356 » Mon Sep 13, 2010 10:56 pm
Yoshi, if I was only going to add 1 more clutch, then I would only need 1 more dog ear plate correct?
From what I can tell from your video, I would just remove the 4mm spacer and that alone would let me add the 3rd clutch. About to order the parts and just trying to make sure I'm getting the right things.
┌∩┐(✖_✖)┌∩┐
AntiSpam:No
Post by Yoshi » Mon Sep 13, 2010 11:20 pm
Yes sir. you are correct. A guy messaged me a while ago about doing 4 clutches without machining the housing. It's possible but the preload will be so high you might as well weld an open diff. I'm not sure if there is any down side to 3 clutches. Uneven lock up? *shrugs*
samiam3356
AntiSpam:No
Post by samiam3356 » Mon Sep 13, 2010 11:47 pm
Was wondering the same. Metric Mechanics picture on the top of their page has the diff showing only 3 clutches and I think they do rebuilds that way as well.
yep they do
http://www.metricmechanic.com/prices/pr ... ntials.php
┌∩┐(✖_✖)┌∩┐
