Yoshi's Differential Rebuild/mod (pre)write up
AntiSpam:No
Re: Yoshi's Differential Rebuild/mod (pre)write up
Post by Yoshi » Mon Sep 13, 2010 11:54 pm
I guess if it works for them. Not an expensive upgrade imo.
do-drift
AntiSpam:No
Post by do-drift » Wed Oct 06, 2010 12:40 am
heya Yoshi new to the forum here not long got an e-30 and looking for some drifty fun, and then looked up diff modifications and happened upon this thread, i was wondering how easy or hard it is to set a diff up as ive never attempted this before, but not afraid of trying, so i spose by reading the thread i get the general idea and principals of it its probs best if i get a spare diff and go from there, if you coud give me some hints tips difficulties etc etc that'd be grets Yoshit cheers in advance,Richard
AntiSpam:No
Post by Yoshi » Wed Oct 06, 2010 1:17 am
Welcome aboard!
The diff is pretty black magic until you attempt it. It goes together and comes apart like anything else in a car. I would recommend writing down and keeping track of the order things came out in. Down to what side it came out of. That way you know everything is back in the right spot. Other than that, it is VERY straight forward.
You might want to get new bolts for the hat piece for the diff itself. I always strip them when taking them out.
do-drift
AntiSpam:No
Post by do-drift » Wed Oct 06, 2010 7:35 am
yeah im looking into this as an investment i live in the uk atm and this is defo a cheaper way of getting more lock than getting a kaaz or other brand name diff's, im not interested if i can do this im a lil nervy about setting up things like backlash etc etc
AntiSpam:No
Post by Yoshi » Wed Oct 06, 2010 2:02 pm
Unless you replace the bearings or are swapping pieces from another diff, you shouldn't have to worry about backlash and pinion depth.
To double check, do the paint method. I think I explained that. If not. I can show you how.
do-drift
AntiSpam:No
Post by do-drift » Thu Oct 07, 2010 5:27 pm
id love to see the methopds included in the re-build as im interested in building this diff set up when i get some more moneys in. to get a spare lsd, is redline diff oil a good oil to use or should i use a crappy one to bed it in? once done that is
AntiSpam:No
Post by Yoshi » Thu Oct 07, 2010 11:25 pm
I used generic gear oil for break in. But it doesn't even seem like it needs it. The fluid was just as clear as when it went in. And i did a full day of slidey slide.
do-drift
AntiSpam:No
Post by do-drift » Fri Oct 08, 2010 12:34 am
yeah i have some redline stuff and there additive to break in gears etc etc. so will most probs use that
EuroDrifter
AntiSpam:No
Post by EuroDrifter » Fri Dec 31, 2010 3:30 pm
Hi ppl ;)
This is my frist post :)
Can some one tell me are the 944 clutches (besides dog ears) same as E30 ones....? Can i use 944 clutches instead of E30 ones?
Tnx
AntiSpam:No
Post by Yoshi » Fri Dec 31, 2010 3:34 pm
I believe this break down is from the 944: http://www.autoatlanta.com/porsche-part ... 305-05.php
The 944 clutches are the same as the stock E30 ones. Bimmer world clutches are better for sport use FYI.
EuroDrifter
AntiSpam:No
Post by EuroDrifter » Fri Dec 31, 2010 3:41 pm
I dont know if they ship international,i`m in Europe ;)
AntiSpam:No
Post by Yoshi » Fri Dec 31, 2010 3:50 pm
I think they do.
wanganstyle
AntiSpam:No
Post by wanganstyle » Wed May 04, 2011 6:55 pm
hey Yoshi-
thanks for using my write up, im glad you are getting use out of it.
with 4 discs, the aftermarket diff builders are modding center section to DECREASE lockup, as the 4 clutch + stock unit is VERY TIGHT.
its durable to a point, I did do alot of drifting with my E36m, but the car was really setup for WANGAN racing @ the top end.
if you are professional drifter, you will run a welded if you are poor, or get a sponsor for a built unit or aftermarket. I prefer KAAZ or cusco for aftermarket, have had those in prior drift cars.
AntiSpam:No
Post by Yoshi » Tue Aug 23, 2011 2:09 pm
updated dog ear plate part number. Someone informed me the part was wrong. Silly me.
Rick
AntiSpam:No
Post by Rick » Sat Dec 03, 2011 7:29 pm
If your ever interested in a locked diff, I like the way this guy did his:
http://e21jps.webs.com/driveline.htm
He's got some other cool shit on his site too.
