Transmission ratios
Transmission ratios
Post by Yoshi » Wed Dec 16, 2009 4:21 pm
getrag 260
1st 3.83:1
2nd 2.20:1
3rd 1.40:1
4th 1.00:1
5th 0.81:1
R 3.71:1
Getrag 250
1st 4.23:1
2nd 2.52:1
3rd 1.66:1
4th 1.22:1
5th 1.0:1
getrag 240
1st 3.72:1
2nd 2.02:1
3rd 1.32:1
4th 1.00:1
5th 0.81:1
R 4.10:1
ZF 320/310
1st 4.2:1
2nd 2.49:1
3rd 1.67:1
4th 1.24:1
5th 1.0:1
R 3.9:1
T56
1st 2.97:1
2nd 2.07:1
3rd 1.43:1
4th 1.00:1
5th 0.84:1
6th 0.56:1
R 2.9:1
Re: Transmission ratios
Post by M20_fever » Wed Dec 16, 2009 4:45 pm
why do you have 6 ratios listed for the G260 and G240?
Post by ten2doyle102 » Wed Dec 16, 2009 4:52 pm
I am assuming that those numbers are the ratios for each gear? Is it also safe to assume that the numbers correspond to the gears like this -> 1-2-3-4-5-R
Post by Yoshi » Wed Dec 16, 2009 5:47 pm
yea. last one is reverse
Post by M20_fever » Wed Dec 16, 2009 6:07 pm
gotcha, so the g250 is only a 4 speed?
Post by Yoshi » Wed Dec 16, 2009 7:34 pm
5 speed
4.23:1
2.52:1
1.66:1
1.22:1
1.0:1
Post by M20_fever » Thu Dec 17, 2009 12:08 am
that doesn't make sense, with that logic the g260 is a 6 speed. You should specify which ratio is for reverse.
Post by Yoshi » Thu Dec 17, 2009 12:55 am
the 6th one if it has one...
Post by M20_fever » Thu Dec 17, 2009 7:07 pm
if it has what, reverse? I would think all transmissions have reverse. A 6 speed indicates 6 forward gears, I'm just saying you should denote that one of those ratios are for reverse.
Post by Yoshi » Thu Dec 17, 2009 7:35 pm
fiiiiiiiiiiiiiiine
Post by M20_fever » Thu Dec 17, 2009 8:54 pm
:mrgreen:
Post by ten2doyle102 » Mon Feb 15, 2010 3:39 pm
8)
Nkululeko81
Post by Nkululeko81 » Thu Jul 28, 2011 7:23 am
Hi Yoshi,
What transmission which Getrag gearbox has numbers 220.0.0225.96?
From which E36 model is that, is it 318iS or 318iS Motorsport 2?
I have a 325i E30 with 2.8 conversion, my diff is 3.15 limited slip and I am currently using some E36 transmission which is running SUPER until around 160km/h where is looses power and the limiter will kick in at 6500rpm and car is at 200km/h on 5th gear which is not really what I had in mind.
I know Getrag 260 will give me longer legs and I will be able to push it towards +/-270km/h. But besides that which other transmission is as good or even better?
Post by Yoshi » Thu Jul 28, 2011 12:21 pm
Welcome aboard!
I have no idea what transmission has that number on it.
For the 2.8 a regular getrag 260 should be fine. Especially with the 3.15 back end. Only other one might be a getrag 240 but then you have to change so much about your setup to fit that trans. I'd say just stick with the 260.
Post by M20_fever » Thu Jul 28, 2011 2:58 pm
G260 is a great all around trans for these cars. Only other trans I would want to run is the euro s50 6 speed with a higher final ratio, but I'm not willing to pay 2500+ USD to get one over here. I don't think you guys got them either.
Welcome to e3p btw!
