Rack and Pinion Rebuild
acolella76
Re: Rack and Pinion Rebuild
Post by acolella76 » Wed Nov 24, 2010 4:52 am
This site is awesome!
Where did you get the seal kit? I just picked up an M3 rack that is leaking like a mofo
Post by Yoshi » Wed Nov 24, 2010 12:55 pm
I've wanted to know this for months lol
acolella76
Post by acolella76 » Wed Nov 24, 2010 4:14 pm
well, i did some searching. Does anyone know if the E36 M3 uses the same seals as the standard E36? Because I found this...
http://www.partsgeek.com/gbproducts/WC/ ... oogle+Base
Post by M20_fever » Wed Nov 24, 2010 6:14 pm
Well the ratios are different, but I'm not sure on the seals.
acolella76
Post by acolella76 » Wed Nov 24, 2010 7:45 pm
the kit i found has 24 seals, the one in the DIY has 23... seems like it would be worth it to try it out. I'll order it and let you guys know, unless anyone can confirm that it won't work
glucklich21
Post by glucklich21 » Fri Dec 17, 2010 4:13 am
Sub'd
Post by Yoshi » Sat Jul 16, 2011 6:27 pm
How the hell do you get the seals out from inside the steering rack? It's half way in and a hammer isn't doing crap. I can barely get on the lip of the seal :(
Post by M20_fever » Sat Jul 16, 2011 10:36 pm
try one of these.
Post by Yoshi » Sun Jul 17, 2011 12:01 am
doesn't fit.
Post by M20_fever » Sun Jul 17, 2011 1:21 am
is this an e36 rack?
Post by ponycarman » Sun Jul 17, 2011 1:53 am
Could try a piece of wire bent over or curled over. Needs to be thick enough to keep from straightening back out.
Post by Yoshi » Sun Jul 17, 2011 3:34 am
E36 rack. It's about a food into the steering tube itself. You can't get anything at it but a really long screw driver or pry bar.
cream
Post by cream » Sun Oct 13, 2013 2:41 pm
revive!!! how did you get that damn thing out yoshi?!?! i've been trying this and that for hours
Post by Yoshi » Sun Oct 13, 2013 3:04 pm
I just knicked at it for a long time till it broke and came out. Then I gave up. The rack is still sitting on my work bench... wow it's been 2 years.
cream
Post by cream » Sun Oct 13, 2013 9:57 pm
aw.. ive been at it for a while now.. now i have even less hope.. lol i think these are a PIA to get out because the ZF used eather teflon or silicone to seal better or meybe just age? ive been trying to soak it in pb plaster and wd40 to loosen it up.. meybe? anything else i can try goo gone? Also i on step #10 the 2nd pic of the metal ring, i cant get it to budge out, "drive out seals" means to bang them out? lol sorry, im confused and flustered on this.. ill attach pics below. also this is a zf 95 m3 rack, i think all e36 use the same seals tho. seems hopeless but any help would be much appreciated. TIA
