Rack and Pinion Rebuild
Re: Rack and Pinion Rebuild
Post by Yoshi » Mon Oct 14, 2013 12:44 am
There's probably a tool that does this... Someone find it. I'm lazy.
cream
Post by cream » Mon Oct 14, 2013 2:01 am
me 1 gasket 0! i rented a tool from autozone lets just hope there is no leaks! :lol:
Post by M20_fever » Mon Oct 14, 2013 2:59 am
I'd love to do this, nice job.
Post by Yoshi » Mon Oct 14, 2013 12:19 pm
I have the same puller. didn't come with that attachment though. I need!
cream
Post by cream » Tue Oct 15, 2013 6:46 pm
i think they called it a "blind hole puller" i had no idea they had a tool like that, i brought in a gasket and the guy at autozone was nice enough to look for the right tool, deposit only free rental, i never rented tools, i thought they charged per day like o'reillys. anyway rack is finished i just hope i didn't mess up the rack from trying to hammer out that stubborn ring. i always used r3v or sometimes e30tech but i love the community here much better. thanks for all the support!
Post by M20_fever » Wed Oct 16, 2013 3:24 am
Nice job, do you run power steering?
cream
Post by cream » Wed Oct 16, 2013 8:36 am
yes with power steering, how do you guys feel about reusing the pressure hose fittings and banjo bolts/washers, they probally are 20ish year old but no noticable cracks, leakage or damage
Post by Yoshi » Wed Oct 16, 2013 11:22 am
Use em till they spring leaks :) cuz I'm cheap as hell.
Post by M20_fever » Wed Oct 16, 2013 3:06 pm
Always use new crush washers, they are one time use.
Post by Yoshi » Wed Oct 16, 2013 4:11 pm
I always reuse them and wind up with tiny TINY weeping connections. Really they are one time use. They should be replaced. Don't do what yoshi does.
cream
Post by cream » Thu Oct 17, 2013 3:19 am
lol, new crush washers, got it. OEM or homedepot same? copper crush washers work? Also should i fill the steering rack with some ATF through the hardline holes? I know its a self bleeding system but will it be ok if its dry for a few seconds?
Post by Yoshi » Thu Oct 17, 2013 10:55 am
When you assemble it, you should use some lube. Because of that, I don't think preoiling is necessary but it wouldn't hurt. Home depot sells crush washers? I thought they sold just regular ones. I'd go with OEM stuff.
Post by M20_fever » Thu Oct 17, 2013 12:56 pm
copper or aluminum, doesn't matter as long as they are the right size. I would just get OEM, their like a dollar each iirc.
JWali
Post by JWali » Thu Jul 21, 2016 5:58 am
Thanks for the great write up. I used sockets that would fit in the rack that were just the right size to drive out the inner seals. Hope that helps others.
Post by Yoshi » Thu Jul 21, 2016 10:51 am
Which sockets?
