Lollipop tech
Re: Lollipop tech
Postby ten2doyle102 » Sat May 26, 2012 3:56 pm
zing! ;)
Re: Lollipop tech
Postby Yoshi » Sun May 27, 2012 1:33 pm
7pilot wrote:Bimmerworld sell a version of the Treehouse style, as well as the Treehouse.
The BW version is slightly cheaper than the TH.
m
link? i can't find it. I no ebay sells a crap version
Re: Lollipop tech
Postby Yoshi » Sun Jun 24, 2012 1:55 pm
bumping this. added more options to the first post. I'm trying to find the best option for the wife's street/track car. I don't really want the spherical due to the constant road use. I could swap with the THR ones on the track E30 though... I'm not sure I could fit my ground out E46 control arms into such tight tolerances.
I remember there was a nylon one but I can't find it. That's the one I want the most. Anyone find it for me?
Re: Lollipop tech
Postby Yoshi » Fri Aug 03, 2012 12:20 pm
updated
Re: Lollipop tech
Postby M20_fever » Fri Aug 03, 2012 12:34 pm
those last ones with the uhmw offset busing for $65 shipped look interesting.
Re: Lollipop tech
Postby Yoshi » Fri Aug 03, 2012 12:43 pm
It's very enticing. I like the delrin/uhmw bushing and feel it should be good enough for the backup track car. But still $65 I just can't justify spending right meow.
Re: Lollipop tech
Postby M20_fever » Fri Aug 03, 2012 12:53 pm
is that per set or per side?
Re: Lollipop tech
Postby Yoshi » Fri Aug 03, 2012 12:57 pm
set. can't imagine per side.
Re: Lollipop tech
Postby Yoshi » Sat Feb 16, 2013 11:03 pm
BAH. I wish these were less than $100 for the good ones >_<
Re: Lollipop tech
Postby Nsquared97 » Tue Mar 26, 2013 4:58 am
Alright guys, I need your help. Plan on refreshing the front end of my car soon (Z3 rack, tie-rods, IE poly steering coupler, control arms, CAB's, IE front sway kit) Coilovers will be in the somewhat nearish future. That said, what should I do for CAB's? The car is going to be autoX'd a lot, but it must still be very enjoyable on the street. I don't mind it being a bit harsh if it makes things feel more solid, but I do not want it to make the driving experience less enjoyable when on relatively smooth roads.
So, OEM, OEM M3, delrin/poly, treehouse style? Offset or centered?
Re: Lollipop tech
Postby Yoshi » Tue Mar 26, 2013 11:16 am
You 100% want something M3 offset. You already posted in DontTrustThisE30's thread. I'd go with the THR ones he's selling. Very good price and the nylon inserts are $10 of you want SUPER fresh ones. I noticed more steering feel with them. It didn't kill the ride by any means. Still streetable but very responsive. There's no reason not to get them IMO.
Re: Lollipop tech
Postby M20_fever » Tue Mar 26, 2013 2:10 pm
your class allows all those mods?
Re: Lollipop tech
Postby ten2doyle102 » Tue Mar 26, 2013 3:12 pm
Same as tony's question...
But for me, I agree with Yoshi. I have them on the 318 and it was not bad at all. Just pray when you take the lollipop bolts out they don't break like mine did... :( Go THR if you're allowed to do that in your classing.
Re: Lollipop tech
Postby Nsquared97 » Tue Mar 26, 2013 5:59 pm
For G Stock, no... but the plan is to switch to STX when I get the coils. Haven't actually looked into if they would allow the treehouse style CAB's, I am pretty sure the normal offset poly ones are allowed.
Re: Lollipop tech
Postby blasphemy101 » Tue Aug 20, 2013 12:40 am
Would a solid aluminum CAB with a plastic insert be noticeably better than the condor ones?
