Lightweight Wheel Options - Listed
Postby ten2doyle102 » Thu Jun 21, 2012 2:47 pm
Well, I have been looking around at wheels alot lately since I was pondering swapping mine out for something different. I didn't really see a nice list laying out decent wheel choice and their weights so I was gonna do that. for us!
I am just gonna start with 15's for now.
Here we go!
949Racing 6ul 15x8 (I have these... ;)
15x8_6ul_b_big by ten2doyle102, on Flickr
Specs:
Weight: 12.8#'s
Offset: +36mm
Hole pattern: 4x100
Center Bore: 67.1mm
http://949racing.com/15x8-6ul-nickel.aspx
Dforce LTW5
dforce 15 by ten2doyle102, on Flickr
Specs:
Weight: 13.0#'s
Offset: +25mm or +30mm
Hole pattern: 4x100
Center Bore: 67.1mm
http://dforcewheels.com/pages/products.php
Konig Flat out
konig_flatout-slv_d by ten2doyle102, on Flickr
Specs:
Weight: 12.4#'s
Offset: +25mm
Hole pattern: 4x100
Center Bore: 73.0mm
http://www.good-win-racing.com/Mazda-Pe ... -0935.html
Konig Wide Open
Konig_WideOpen_15x8 by ten2doyle102, on Flickr
Specs:
Weight: 13.8#'s
Offset: +20mm or +25mm
Hole pattern: 4x100
Center Bore: 73.0mm
http://www.good-win-racing.com/Mazda-Pe ... -1013.html
Enkei RPF1
RPF1 by ten2doyle102, on Flickr
Specs:
Offset: 35 or 41
Bolt Pattern: 4x100
Bore Diameter: 73
Weight (lbs): 9.9
http://www.vividracing.com/catalog/enke ... 24879.html
Team Dynamics Pro Race 1.2
team dynamics 1.2 by ten2doyle102, on Flickr
Specs:
Weight: 15.1#'s
Offset: Many different offsets avaliable
Hole pattern: 4x100
Center Bore: 57.1mm
http://www.outmotoring.com/mini-cooper/ ... -race.html
TRMotorsports C1
TRM C1 by ten2doyle102, on Flickr
Specs:
Offset: +25mm
Bolt Pattern: 4-100
Weight: 13.6lbs.
http://www.tirerack.com/wheels/WheelClo ... sort=Price
Kosei K1
kosei_k1racing_s_ci3_l by ten2doyle102, on Flickr
Specs:
Offset: 25mm
Backspacing: 5.00"
Bolt Pattern: 4-100
Rec. Tire Size: 205/55-15
Weight: 13.3lbs.
Finish: Silver Painted
Construction: 1pc. Low Pressure Cast/Shot Peened
Finish Warranty: 1 Year
Manufactured in Thailand
http://www.tirerack.com/wheels/WheelClo ... ort=Weight
Kosei K4r
kosei_k4r_lg_ci3_l by ten2doyle102, on Flickr
Specs:
Offset: 20mm
Backspacing: 5.27"
Bolt Pattern: 4-100
Weight: 13.1lbs.
Finish: Light Grey Painted
Construction: 1pc. Gravity Cast w/ Flow Form Rim
Manufactured in Japan
Enkei Classic J-Speed
ecs_jspeed_sml_ci3_l by ten2doyle102, on Flickr
Specs:
Offset: 25mm
Backspacing: 4.96"
Bolt Pattern: 4-100
Weight: 14.6lbs.
Finish: Silver w/Machined Lip
Construction: 1 Pc. gravity Cast
Manufactured in China
Dontrusthise30
Re: Lightweight Wheel Options - Listed
Postby Dontrusthise30 » Thu Jun 21, 2012 2:53 pm
Good idea! Might want to add the spacer sizes required for the 6ul's as well and for any others that need it.
Postby ten2doyle102 » Thu Jun 21, 2012 2:57 pm
Yeah, I thought about that, but really that comes down to the person and what they are looking for. Plus, the only one I really know is the 6uls. I am not sure on the rest. :)
Postby Yoshi » Thu Jun 21, 2012 3:03 pm
<3 the RPF1s
Postby ten2doyle102 » Thu Jun 21, 2012 3:22 pm
I was thinking about going to those but they are so dang expensive! Almost $200/wheel!
Postby Nsquared97 » Thu Jun 21, 2012 4:42 pm
Nice! May want to include the C1 is available in 15x7 and 15x8.
Also Tire Rack has the Kazera k4r which is another good lightweight choice too.
Postby ten2doyle102 » Thu Jun 21, 2012 4:57 pm
I have to add several others like those and Kosei K1's as well!
Postby AustinR » Fri Jun 22, 2012 12:30 am
Awesome list man! Thanks.
Postby ten2doyle102 » Wed Jun 27, 2012 4:14 pm
http://www.good-win-racing.com/Mazda-Pe ... heels.html
This site is pretty good for finding alot of decent lightweight wheels. Check it out! :)
Postby M20_fever » Wed Jun 27, 2012 7:01 pm
Good info deserves sticky.
Postby ten2doyle102 » Wed Jun 27, 2012 7:11 pm
-yuush- -grin-
