rear trailing arm bushings
Re: rear trailing arm bushings
Postby Yoshi » Sat Jul 21, 2012 12:47 pm
You won't break it break it. You'll just wear the U joint out sooner. You're probably right in this instance. The axles need to be parallel with your welded diff. Ironic username btw.
-LSD-
Postby -LSD- » Mon Jul 23, 2012 9:49 pm
lol thanks. But if you think about that 12mm will effect short axles more than longer driveshaft. Angle change on the driveshaft itself won't be that big, so i won't be too worry about it. But yeah in a long run it prolly will wear out ujoints faster.
Alex K.
Postby Yoshi » Tue Jul 24, 2012 12:06 am
Yea. I just used some washers lol. prob like 4mm worth.
-LSD-
Postby -LSD- » Thu Jul 26, 2012 4:32 am
Yoshi wrote:Yea. I just used some washers lol. prob like 4mm worth.
dafak xD great "differential lowering kit" KIT is that what you call it? -grin-
Alex K.
Postby Yoshi » Thu Jul 26, 2012 12:44 pm
*shrugs* do what works :)
