How to keep coilover rear springs from falling out?
Postby Yoshi » Fri Jul 12, 2013 11:29 am
I set my car to stupid max low and the springs just kinda fall out when I jack up the car. I don't mind resetting them before I put the car back down but if my wife takes the car to a shop or something, I don't want the car falling on its ass. Thoughts?
Re: How to keep coilover rear springs from falling out?
Postby 87e30 » Fri Jul 12, 2013 3:55 pm
lol, reminds me of my friends old MX-6. He cut the springs to the point where even without being jacked up it was almost as if there were no spring there. To lower the car without losing a spring it took 2 people and 2 jacks. I know that story is of absolutely no use to you, but it was still funny. :-P
Postby M20_fever » Fri Jul 12, 2013 4:26 pm
heavy duty zip ties. Strap the spring around the bottom coil to the lower perch.
Postby Yoshi » Fri Jul 12, 2013 4:28 pm
M20_fever wrote:heavy duty zip ties. Strap the spring around the bottom coil to the lower perch.
how?
Postby M20_fever » Fri Jul 12, 2013 4:31 pm
your a drifter, I need to explain the use of zip ties?
for realz though, there isn't a small hole in the lower perch you could put the tie through?
Postby Yoshi » Fri Jul 12, 2013 4:33 pm
nope...
Postby M20_fever » Fri Jul 12, 2013 5:02 pm
post a pic of the rear suspension.
Postby Yoshi » Fri Jul 12, 2013 5:31 pm
Postby M20_fever » Fri Jul 12, 2013 6:21 pm
run the tie through the adjuster grooves around the bottom of the adjuster and over the bottom coil.
Postby Yoshi » Fri Jul 12, 2013 6:30 pm
I'll give it a shot.
Postby Nsquared97 » Fri Jul 12, 2013 8:31 pm
M20_fever wrote:your a drifter, I need to explain the use of zip ties?
Hahahahaha!!!
Mne666
Postby Mne666 » Sun Aug 11, 2013 7:49 am
To fit coilovers as a pose to normal lowering springs and shocks did you have to make any mods to the car? Or could i just buy some and give it to my mechanic to do as a normal suspension swap
Postby M20_fever » Mon Aug 12, 2013 4:10 am
you need to mod the front strut housing's, and unless you do significant mods in the rear you can do a true coil overs. The kits come with everything you need to mod the struts, so if you use a competent mechanic that can weld properly he should be able to handle it.
