Suspension buffet - AKA what am I doing?
Re: Suspension buffet - AKA what am I doing?
Postby Nsquared97 » Thu Jul 18, 2013 9:56 pm
Yeah I think the SS lines are rebranded, but they were the cheapest DOT rated lines I found. My front sway is the biggest they offer and it fit just fine, but yes it is hollow.
Postby Yoshi » Fri Jul 19, 2013 12:23 am
fronts are easy. IIRC it's the rears that require the mods.
u3b3rg33k
Postby u3b3rg33k » Tue Aug 20, 2013 12:44 am
OK some driveshaft talk. CSB's hate me (not the bearings, but the rubber always craps out), so I'm thinking of doing this:
http://www.driveshaftshop.com/import-dr ... driveshaft
same price (roughly) as OE - any reason I should NOT do this?
thanks.
and go ahead and make this a build thread.
Postby 87e30 » Tue Aug 20, 2013 3:29 am
Does that come with 2 solid metal flex discs? Why 2? That's a bit more than I wanted to spend on a driveshaft, but I might have to consider it for the future.
u3b3rg33k
Postby u3b3rg33k » Tue Aug 20, 2013 5:09 am
they're bolt-hole adapters - not "guibos". I'll have to verify that they'll bolt to my triangle flange trans. compared to a DS straight from BMW, the price really isn't that bad.
Postby Yoshi » Tue Aug 20, 2013 11:13 am
Meh, if you want to spend $800, sure. You probably keep killing CSBs because your DS isn't balanced. A balance is like $50 or something. Worst case, your U joints are dead. I forget the rebuild costs Robert did but it def wasn't $800.
Postby 87e30 » Tue Aug 20, 2013 2:52 pm
u3b3rg33k wrote:they're bolt-hole adapters - not "guibos". I'll have to verify that they'll bolt to my triangle flange trans. compared to a DS straight from BMW, the price really isn't that bad.
If you want to get picky it is "giubo", not "guibo", so we've all been saying/spelling it wrong the whole time. lol Point is do they mount where BMW originally placed the flex disc (by whatever name you call it)?
Postby M20_fever » Tue Aug 20, 2013 3:40 pm
go to a local drive shaft shop, you'll get a much better price on a custom 1 piece shaft. I was quoted $300 a couple years ago. You wouldn't need to worry about those bolt adapters either, it would be direct fit with u-joints.
