J-Stock springs cancelled..?
Postby blasphemy101 » Fri Aug 30, 2013 2:33 pm
Just a heads-up...
I've exchanged emails/phone calls with sales reps at Turner Motorsports over the last couple of days. They are ending production of the J-Stock springs. They have plenty of the dampers left, but I've placed an order for one of the two remaining sets of springs. So there's one set left waiting for one of you guys on the fence to pick it up...
Dontrusthise30
Re: J-Stock springs cancelled..?
Postby Dontrusthise30 » Fri Aug 30, 2013 3:04 pm
Interesting, they give any reason?
Postby Yoshi » Fri Aug 30, 2013 5:59 pm
oh yea. Didn't we discuss this a while ago? For the cost of Jstock, you can get the best coilovers with any rates you want. So aside from the progressive 200-900 front springs, you can get jstock for less.
Postby blasphemy101 » Fri Aug 30, 2013 7:04 pm
Since the j-stock class was cancelled I guess there is just a lack of demand. The j-stock dampers should be a good bit better than comparatively priced coilovers...
Postby Yoshi » Sat Aug 31, 2013 12:21 am
Yes and no. GC custom valves for you. And they are adjustable.
Postby M20_fever » Sat Aug 31, 2013 6:21 pm
sad to hear this...really didn't think it would happen for a good while. Can you set up coil overs to perform as well, yes. Do most people have the skill to do so, No. I've ridden in several e30s on coils and none have cone close to handling like my j-stocks.
Postby Ryki » Sun Sep 01, 2013 4:58 pm
I had wanted a set so bad :/
Postby Yoshi » Sun Sep 01, 2013 5:36 pm
1 left!
Postby blasphemy101 » Sun Sep 01, 2013 11:36 pm
Yoshi wrote:Yes and no. GC custom valves for you. And they are adjustable.
Well yeah, but aren't GC coilovers like $1400?
Postby blasphemy101 » Sun Sep 01, 2013 11:40 pm
M20_fever wrote:sad to hear this...really didn't think it would happen for a good while. Can you set up coil overs to perform as well, yes. Do most people have the skill to do so, No. I've ridden in several e30s on coils and none have cone close to handling like my j-stocks.
The dampers should be available from Turner for some time, after that you can have Bilstein Sports revalved. It's unfortunate that the springs are going, though. From what I could tell, they were really the only off-the-shelf option appropriate for real track usage.
Postby Yoshi » Mon Sep 02, 2013 12:21 am
$1700. Full J stock is $2000
Postby M20_fever » Mon Sep 02, 2013 5:57 am
The $2000 is for a lot more than just the springs and dampeners, it includes front and rear sway bars, rsms, front camber plates, rear strut tower reinforcements, and sway bar mount reinforcements. I just checked their site and they don't even list a full J-Stock kit anymore, just springs and dampeners sold separately. For just the shocks and springs it was right around $900 shipped.
Postby M20_fever » Mon Sep 02, 2013 6:09 am
Never mind, its still listed as a complete kit: http://www.turnermotorsport.com/p-4076- ... nsion.aspx
Postby Ryki » Tue Sep 10, 2013 5:32 pm
Well they are certainly gone. Called to see if I could grab the last set but work kept me from doing so. If anyone sees someone selling an old set please let me know :/
Postby blasphemy101 » Tue Sep 10, 2013 5:38 pm
I'm sorry to hear that Ryki - it may be possible to go with the J-Stock dampers and use appropriately-rated Ground Control springs. Actually...That sounds like a nice setup!
