Swaybar bushing mount bracket
Hi all, I am new to the forum and E30's, BMW period. I bought a 1987/88 325ic. Needed a lot of suspension work. I pretty much replaced the whole front end, including front subframe (used) because it was broken on one side where bushing bracket bolts on. Everything was fine for a few months. Now the second subframe brokeoff too.
A used subframe is not expensive but there is a lot of labor involved. Before I buy another one, wanted to find out if is it just my bad luck or it is a common problem with e30's!
I have not found any threads on this topic anywhere...
- Yoshi
- Site Admin
- Contact:
Re: Swaybar bushing mount bracket
broke? You sure?
Can you post pictures?
welcome!
welcome!
- M20_fever
- Größter Vorsitzender
yeah, need to see pics to tell whats going on, but I can tell you broken subframe is not a common e30 problem.
Thank you guys, I will try to post a pic tomorrow...
Post a bunch of pics and start a build thread. Welcome aboard!
