MVRK - DIY - Keyless Entry System for $25 and 30 minutes wor
mvrk10256
Postby mvrk10256 » Wed Nov 30, 2011 5:40 pm
DIY: Remote Electronic Locks for $25
First the kit: It is called Omega REC-43T Keyless Entry System, and you can get it off ebay. I got it from a guy called tintnelectronics. Good guy, shipped quick.
Basically this a radio frequency programable clicker. You can use this to open your car, your garage, trigger any electronically controlled device. There is nothing that makes this kit "car" specific.
First impression - Chinese quality box, but the clickers and the box feel solid. Seem to made pretty well, only time will tell. The provided instruction are good, in grammatically correct English, and all in all provide us with a good idea of how to start. Having a voltmeter helps, or you can just fallow my wire guide.
1. Remove the trunk lining between tail lights
(I dont have it in anyway so I didnt show how to do this)
These are the wires we are looking for.
2. Disconnect your battery - we will be dealing with hot wires - since the system continuously draws power - so disconnect at the source.
3. The kit comes with two bundles - here is what the basic wires will look like
4Wire bundle
OMEGA wire Color ----Car functions----Car wire color
Red ------------------+12V------------Red (antenna wire)
Black ----------------Ground-----------brown (bunch at trunk lock)
Green ------------Output 3-----------not used
Blue --------------output 4------------not used
2 Wire bundle
Green -----------Lock-------------Green and black stripe
Blue--------------unlock----------green with purple stripe
4.Our hot wire for constant 12V
5.bundle that runs to trunk lock
6.double sided tape on back of main box for attachment
7.soldering in power wire
8.box mounted
9.ground wire soldered in
10.all wires soldered in
11.and clean it up
12. Reconnect your battery - or else nothing will work.
Optional: The stock antenna is pretty short and since I cut off the extra lengths of wire anyways as I was installing it I decided to use them to extend th antenna. I then rn it around the edge of the trunk and up underneath the speaker tray area - range is good.
Done:
Locks in work:
http://www.youtube.com/watch?v=N13QNrnpBc8
NOTE: to get no delay you need to turn the delay dial on teh board all the way counter clockwise and then click channels 1 and 2 down to the (-) notch. That smoothed out operation a lot for me.
-Maksim
Re: MVRK - DIY - Keyless Entry System for $25 and 30 minutes
Postby M20_fever » Wed Nov 30, 2011 6:02 pm
I know I sound like a broken record here, but I'll say it again...sticky. :)
Postby ponycarman » Wed Nov 30, 2011 6:03 pm
He's gonna be swimming in stickers lulz ;)
Postby M20_fever » Wed Nov 30, 2011 6:13 pm
technically its got to be on the stickers for stickies list, but in this case I can make an exception, lol.
mvrk - pm for set of free e3p stickers. ;)
mvrk10256
Postby mvrk10256 » Wed Nov 30, 2011 7:15 pm
Haha. If I can make it to winter break, there will be more to come.
-Maksim
euro2fast4u
Postby euro2fast4u » Wed Nov 30, 2011 8:07 pm
can you make one for an e36 :) pwease
mvrk10256
Postby mvrk10256 » Wed Nov 30, 2011 9:49 pm
euro2fast4u wrote:can you make one for an e36 :) pwease
I dont have an e36, and I dont have any friends with one, but I see no reason why this could not be made to work. If you have power locks all you really need is to figure out which wire is which (unlock and lock) and do it the exact same way. All the device does is connect +12V to the "lock" or "unlock" wire when you press a button.
-Maksim
Postby 87e30 » Thu Dec 01, 2011 12:59 am
Not only do I have to do this to my car now (or a full alarm with keyless entry and all), but now I know which wire is which so I can hopefully troubleshoot my recent lock issue. Couldn't find the wiring diagram for the locks in Mitchell On Demand.
mvrk10256
Postby mvrk10256 » Thu Dec 01, 2011 2:29 am
87e30 wrote:Not only do I have to do this to my car now (or a full alarm with keyless entry and all), but now I know which wire is which so I can hopefully troubleshoot my recent lock issue. Couldn't find the wiring diagram for the locks in Mitchell On Demand.
Not sure what Mitchell on Demand is, but I hope this helped.
-Maksim
Postby 87e30 » Thu Dec 01, 2011 3:23 am
It's a computer program that's supposed to have full wiring diagrams and MUCH more info for just about every car ever produced. I was able to use a copy to look up my car, and printed out everything I could, but I didn't see power locks listed.
mvrk10256
Postby mvrk10256 » Thu Dec 01, 2011 3:17 pm
87e30 wrote:It's a computer program that's supposed to have full wiring diagrams and MUCH more info for just about every car ever produced. I was able to use a copy to look up my car, and printed out everything I could, but I didn't see power locks listed.
Thats pretty boss. where do you get it? access to it?
-Maksim
Postby 87e30 » Thu Dec 01, 2011 3:52 pm
Not sure where you get it, but a lot of auto repair shops have it. I think you have to pay a subscription for access to it like AllData.
mvrk10256
Postby mvrk10256 » Thu Dec 01, 2011 4:57 pm
87e30 wrote:Not sure where you get it, but a lot of auto repair shops have it. I think you have to pay a subscription for access to it like AllData.
That makes sense. Will have to try to pirate it.
-Maksim
ss45466
Postby ss45466 » Fri Dec 02, 2011 3:15 pm
Hope this helps:
grin
euro2fast4u
Postby euro2fast4u » Fri Dec 02, 2011 7:39 pm
asked for two of these for christmas!!!
Return to “Electrical”
