Page 1 of 3
MVRK - DIY - Keyless Entry System for $25 and 30 minutes wor
Posted: Wed Nov 30, 2011 5:40 pm
by mvrk10256
DIY: Remote Electronic Locks for $25
First the kit: It is called Omega REC-43T Keyless Entry System, and you can get it off ebay. I got it from a guy called tintnelectronics. Good guy, shipped quick.
Basically this a radio frequency programable clicker. You can use this to open your car, your garage, trigger any electronically controlled device. There is nothing that makes this kit "car" specific.
First impression - Chinese quality box, but the clickers and the box feel solid. Seem to made pretty well, only time will tell. The provided instruction are good, in grammatically correct English, and all in all provide us with a good idea of how to start. Having a voltmeter helps, or you can just fallow my wire guide.
1. Remove the trunk lining between tail lights
(I dont have it in anyway so I didnt show how to do this)
These are the wires we are looking for.
2. Disconnect your battery - we will be dealing with hot wires - since the system continuously draws power - so disconnect at the source.
3. The kit comes with two bundles - here is what the basic wires will look like
4Wire bundle
OMEGA wire Color ----Car functions----Car wire color
Red ------------------+12V------------Red (antenna wire)
Black ----------------Ground-----------brown (bunch at trunk lock)
Green ------------Output 3-----------not used
Blue --------------output 4------------not used
2 Wire bundle
Green -----------Lock-------------Green and black stripe
Blue--------------unlock----------green with purple stripe
4.Our hot wire for constant 12V
5.bundle that runs to trunk lock
6.double sided tape on back of main box for attachment
7.soldering in power wire
8.box mounted
9.ground wire soldered in
10.all wires soldered in
11.and clean it up
12. Reconnect your battery - or else nothing will work.
Optional: The stock antenna is pretty short and since I cut off the extra lengths of wire anyways as I was installing it I decided to use them to extend th antenna. I then rn it around the edge of the trunk and up underneath the speaker tray area - range is good.
Done:
Locks in work:
http://www.youtube.com/watch?v=N13QNrnpBc8
NOTE: to get no delay you need to turn the delay dial on teh board all the way counter clockwise and then click channels 1 and 2 down to the (-) notch. That smoothed out operation a lot for me.
Re: MVRK - DIY - Keyless Entry System for $25 and 30 minutes
Posted: Wed Nov 30, 2011 6:02 pm
by M20_fever
I know I sound like a broken record here, but I'll say it again...sticky. :)
Posted: Wed Nov 30, 2011 6:03 pm
by ponycarman
He's gonna be swimming in stickers lulz ;)
Posted: Wed Nov 30, 2011 6:13 pm
by M20_fever
technically its got to be on the stickers for stickies list, but in this case I can make an exception, lol.
mvrk - pm for set of free e3p stickers. ;)
Posted: Wed Nov 30, 2011 7:15 pm
by mvrk10256
Haha. If I can make it to winter break, there will be more to come.
Posted: Wed Nov 30, 2011 8:07 pm
by euro2fast4u
can you make one for an e36 :) pwease
Posted: Wed Nov 30, 2011 9:49 pm
by mvrk10256
euro2fast4u wrote:can you make one for an e36 :) pwease
I dont have an e36, and I dont have any friends with one, but I see no reason why this could not be made to work. If you have power locks all you really need is to figure out which wire is which (unlock and lock) and do it the exact same way. All the device does is connect +12V to the "lock" or "unlock" wire when you press a button.
Posted: Thu Dec 01, 2011 12:59 am
by 87e30
Not only do I have to do this to my car now (or a full alarm with keyless entry and all), but now I know which wire is which so I can hopefully troubleshoot my recent lock issue. Couldn't find the wiring diagram for the locks in Mitchell On Demand.
Posted: Thu Dec 01, 2011 2:29 am
by mvrk10256
87e30 wrote:Not only do I have to do this to my car now (or a full alarm with keyless entry and all), but now I know which wire is which so I can hopefully troubleshoot my recent lock issue. Couldn't find the wiring diagram for the locks in Mitchell On Demand.
Not sure what Mitchell on Demand is, but I hope this helped.
Posted: Thu Dec 01, 2011 3:23 am
by 87e30
It's a computer program that's supposed to have full wiring diagrams and MUCH more info for just about every car ever produced. I was able to use a copy to look up my car, and printed out everything I could, but I didn't see power locks listed.
Posted: Thu Dec 01, 2011 3:17 pm
by mvrk10256
87e30 wrote:It's a computer program that's supposed to have full wiring diagrams and MUCH more info for just about every car ever produced. I was able to use a copy to look up my car, and printed out everything I could, but I didn't see power locks listed.
Thats pretty boss. where do you get it? access to it?
Posted: Thu Dec 01, 2011 3:52 pm
by 87e30
Not sure where you get it, but a lot of auto repair shops have it. I think you have to pay a subscription for access to it like AllData.
Posted: Thu Dec 01, 2011 4:57 pm
by mvrk10256
87e30 wrote:Not sure where you get it, but a lot of auto repair shops have it. I think you have to pay a subscription for access to it like AllData.
That makes sense. Will have to try to pirate it.
Posted: Fri Dec 02, 2011 3:15 pm
by ss45466
Hope this helps:
grin
Posted: Fri Dec 02, 2011 7:39 pm
by euro2fast4u
asked for two of these for christmas!!!
