obc question...
obc question...
Post by 87e30 » Thu Feb 09, 2012 7:50 pm
How on earth do you switch it from kilometers back to miles? -dizzy-
Re: obc question...
Post by M20_fever » Thu Feb 09, 2012 9:12 pm
Found this in R3v a while back.
select RANGE and then using a ballpoint pen, press the small reset button in the bottom right corner. This will show a different count for: Range, AVG MPG, AVG MPH, and TEMP.
Re: obc question...
Post by 87e30 » Thu Feb 09, 2012 9:24 pm
Right after I posted that I actually found a post on bimmerfest that had a link to a thread on r3v with a bunch of info. It's actually AVG MPG, not RANGE, btw. The mistake is pointed out later in the same thread. Now if I could only set my clock.... :-P
Re: obc question...
Post by Nsquared97 » Fri Feb 10, 2012 7:31 am
This has everything you want to know about the OBC:
http://www.strictlyeta.net/technical/obcfunctions.html
