ACK! I need to use hand signals when turning!
Postby 87e30 » Wed Apr 23, 2014 11:14 pm
Yesterday morning my blinkers worked all the way to work until I was a block away, making a left turn in front of a cop who was driving toward me. I flicked my blinkers on, as I always do when turning, but no blinkage. When leaving work yesterday I checked them, still not working, looked at the fuse, which didn't look blown, but decided to change it anyway. New fuse and blinkers work fine. Put the original fuse in and blinkers still work fine. Drive home to realize blinkers are not working again. This morning I play with the fuse when leaving for work and still no blinkers, and also notice wipers do not work either. Now the wiper switch has always given me problems due to the cruise controls being floppy, but before this they always worked if I jiggled the cruise. My hazard lights do function normally. Any idea what could be wrong with my blinkers and wipers now?
Re: ACK! I need to use hand signals when turning!
Postby Yoshi » Thu Apr 24, 2014 12:25 am
Switch is probably on the fritz. Make sure the wiring is done right on it.
Postby M20_fever » Thu Apr 24, 2014 3:07 am
yeah sounds like the switch going bad.
Postby 87e30 » Thu Apr 24, 2014 1:16 pm
I slapped the top of the fuse box and everything started working again. I'm thinking bad connection on a relay.
Postby Yoshi » Thu Apr 24, 2014 3:29 pm
Pretty sure those relays aren't in the fuse box. Turn signal ones are under the steering column IIRC.
ivprodigy
Postby ivprodigy » Thu Apr 24, 2014 9:51 pm
The turn signal relay is under the steering column see pic below.
It sounds like it could be a bad ground. My car's wiper wouldn't work until I installed the turn signal stalk (which my car didn't have) and connected the turn stalk ground.
Postby 87e30 » Thu Apr 24, 2014 10:19 pm
Well I had the wipers and blinkers turned on when I smacked the top of the fuse box. I heard and felt a click in one of the relays, don't ask me which one, and all of a sudden the blinker was blinking, and the wipers were wiping. It works, I'm not gonna mess with it. lol
Postby Yoshi » Thu Apr 24, 2014 10:40 pm
Yay german electrical gremlins.
Postby M20_fever » Fri Apr 25, 2014 3:18 am
haha, nice. Just hit the junk yard and grab a handful of relays and replace them all.
Postby Ryki » Fri Apr 25, 2014 7:13 am
Yeah, grounding relay or the actual connection at the light. Mine was doing it randomly so I just slapped the actual lens cover to the blinker a few times and it's worked since. Good thing it did cause I was in Austria when they went out...
Postby Yoshi » Fri Apr 25, 2014 11:34 am
Most of those relays are just regular ones. I think you can even get them from the "down the street" auto store.
I stared at my diagrams a bit. The horn relay is the #2 relay in the fuse box. If you stand on the driver's side fender staring at the fuse box, it's second from the left on the bottom row.
FYI
Postby 87e30 » Fri Apr 25, 2014 12:31 pm
M20_fever wrote:haha, nice. Just hit the junk yard and grab a handful of relays and replace them all.
I've got bags full of original BMW fuses and relays from the yards. :-D Oh yeah, the little plastic fuse pullers too.
Now I just need to get another fuse box cover. I had one that wasn't cracked, but my hood popped open while driving 60mph (damn New Jersey potholes) and it flew out. I have one that's in mint condition, but I don't want to use it lol, those things are hard to find.
Postby 87e30 » Fri Apr 25, 2014 12:34 pm
Yoshi wrote:Most of those relays are just regular ones. I think you can even get them from the "down the street" auto store.
I actually used one of my spare BMW fuses when troubleshooting the problem with the flatbed yesterday while I was waiting for the $8 relay from Pep Boys to get delivered. Why on earth are they so expensive there? I get them for 45 cents each from my supplier in Long Island.
Postby Yoshi » Fri Apr 25, 2014 12:42 pm
lol fuse cover flew away. Never seen that happen before.
Postby 87e30 » Fri Apr 25, 2014 1:36 pm
It actually happened to me twice in the same car. I have since lubricated the shit out of my hood latch so it locks properly and the hood no longer pops open when I'm driving.
