Where can I tap for a key on relay?
Postby Yoshi » Mon Apr 28, 2014 12:10 am
Apparently I literally ripped out ALL the stereo wiring in my car. Well now I want a stereo back damnit. But none of the wiring is there. So I need to wire in a relay that will power the stereo when the car is on the "on" position. Suggestions?
Re: Where can I tap for a key on relay?
Postby M20_fever » Mon Apr 28, 2014 3:19 am
Why can;t you use the same relay the stock stereo used? You pulled the wiring out, but did you pull the whole fuse block out? If so, why not just use a standard relay and use the aux position on the ignition switch as the trigger wire, and a direct line to the battery + for power?
Postby Ryki » Mon Apr 28, 2014 6:50 am
Just be careful because that type of wiring is what causes the radio to stay on and kill your battery... If only I didn't hate electrical...
Postby Yoshi » Mon Apr 28, 2014 10:31 am
I can't seem to find the stereo wiring in my diagrams and I don't remember how far I pulled the wiring. I don't even recall where the relay is that the factory head unit used. I don't really want to tap directly from the ignition but I'll guess I'll do that if need be.
Postby blasphemy101 » Mon Apr 28, 2014 7:44 pm
I can scan the diagrams out of my bentley if you want. Just let me know before Thursday - that's the last day I'll be at school this semester.
Postby Yoshi » Mon Apr 28, 2014 9:22 pm
oh yea. I have a bently manual !
Postby 87e30 » Mon Apr 28, 2014 10:15 pm
I thought we all did. I keep my hard copy on my back seat, and have a digital copy on no less than 2 computers.
Postby Yoshi » Tue Apr 29, 2014 12:50 am
I usually know everything so I hardly use it. Sounds pompous but it's honest lol.
Postby 87e30 » Tue Apr 29, 2014 2:50 pm
Yoshi wrote:I usually know everything
mmm hmm... :-P
Postby Ryki » Wed Apr 30, 2014 8:49 am
How many years/E30s/Engine Swaps have you done, Yoshi?
Postby Yoshi » Wed Apr 30, 2014 11:16 am
I've owned 85/87/88/89/90. I don't think I've owned an 86 or 91 but I might have. Oh yea, my last auto was a 91. So I'm missing 84/86. Though 86 is also debatable.
I've had autos/manuals/is/i/e/es models. No AWD models though. I've also yanked a lot of motors but only put back in M20s or M50 variants. I refuse to put a 4 banger in an E30 :)
Postby Ryki » Wed Apr 30, 2014 8:41 pm
Wow. Well hopefully you can a radio figured out for the new beast-
Return to “Electrical”
