Electric locks cycle to "locked" after being unlocked
EBSF
Postby EBSF » Sat Aug 30, 2014 2:49 am
This just cropped up. The doors automatically lock themselves whenever they are unlocked in any manner (using door key, lifting the lock knob, or using the trunk lock).
Furthermore, with the driver door open, the locks cycle unlocked-locked 2-6 times. I note that designed behavior is that if the driver door is open, locking the trunk locks the doors before they cycle open (but just once).
Any thoughts on where the fault may lie, before I dig further in? The only work on the car was removing and re-installing the trunk lining in connection with a suspension overhaul a few months ago. I'm thinking either the trunk lock or the lock control unit. Also, does anyone have a part no. for the lock control unit, because I don't see it on the ETK.
Re: Electric locks cycle to "locked" after being unlocked
Postby Yoshi » Sat Aug 30, 2014 2:30 pm
The reason it unlocks immediately is that something isn't working right with the lock itself. If it can't fully lock, it'll unlock. Just gotta figure out which one isn't locking...
EBSF
Postby EBSF » Sun Aug 31, 2014 6:35 pm
Actually, the problem is that it locks immediately, not that it unlocks immediately. It only unlocks when the driver's door is open, which is what it's supposed to do. Problem is, it then cycles itself to, "locked" and reiterates.
Postby pr0craztinazn » Mon Sep 01, 2014 11:11 am
Lock contrul unit part #: 61 31 1 380 302 (same on my '87 and my '90; no clue for earlier models).
Useful FAQs:
http://nomad-bmw.blogspot.com/2012/10/e ... ssues.html
http://www.e30zone.net/e30zonewiki/inde ... g_problems
http://www.mesaperformance.com/faqs/centlock.html
Your problem is likely related to a lock solenoid or one of the common wiring faults described above.
Postby Yoshi » Tue Sep 02, 2014 11:31 am
Must... bookmark this. Want electronic locks in the race car.
