How can I figure out WHY my tach isn't working?
Re: How can I figure out WHY my tach isn't working?
Post by 87e30 » Tue Oct 28, 2014 10:20 pm
After all that it was just the fuse? Isn't that usually the first thing to check? That reminds me. I have to replace the fuse for my blower motor that must have blown when I had my timing belt done.
Post by Yoshi » Wed Oct 29, 2014 12:42 pm
And the SI batteries. I think. Yea.. shoulda checked that. I only found one fuse for the cluster so I figured that was it. Cruising forums, someone pointed that other fuse out and I was like "omg".
Course, now I have to find someone locally with an hp tuner to futz with my tach.
Post by M20_fever » Thu Oct 30, 2014 2:46 am
What "adjustment" did the "tuners" make to the tach signal?
Post by Yoshi » Thu Oct 30, 2014 3:19 pm
In the HP tuner software, there's actually a few outputs you can do to change what gets set on the tach. I've seen E36 guys run their tach with just the ECU tuning and nothing else. Since the M50 based motors work on E30 clusters for rpms, I figured it should work on E30s as well. Right?
Post by M20_fever » Thu Oct 30, 2014 11:29 pm
meh, I'll sell you my MS3x, problem solved.
Post by Yoshi » Fri Oct 31, 2014 11:18 am
Fix one problem to create 99 other ones? Shiiiiiiiiit
Post by 87e30 » Fri Oct 31, 2014 12:21 pm
I got 99 problems, but a tach ain't one.
