Want to be in our banner? Post your pics here!
Post your suggestions for our site
Re: Want to be in our banner? Post your pics here!
Postby M20_fever » Wed Dec 08, 2010 1:48 am
worth the wait. :)
Postby M20_fever » Wed Dec 22, 2010 2:39 pm
Any new pics ya'll want added to our banner? I need a few more good ones to work up another batch to upload.
Postby Yoshi » Wed Dec 22, 2010 3:53 pm
nudes of wives/gfs. It'll spice this place up.
Postby ten2doyle102 » Wed Dec 22, 2010 4:37 pm
that would be interesting..... LOL!
Postby M20_fever » Wed Dec 22, 2010 7:10 pm
Lead by example Yosh! :wink:
Postby ten2doyle102 » Wed Dec 22, 2010 8:05 pm
Tony read my mind on that one..... ;)
Postby Yoshi » Wed Dec 22, 2010 8:07 pm
<_< whatevs
dmcl
Postby dmcl » Sat Jan 01, 2011 5:07 pm
use any or all of them if u want. i got some higher res versions of most, maybe all of them too if u need any..
Postby M20_fever » Sat Jan 01, 2011 6:16 pm
good ones! I should have enough to start working up some new banners, but keep posting new pics!
dmcl
Postby dmcl » Sun Jan 02, 2011 4:54 pm
hopefully be going to another dyno day soon-ish so i should have some more pics after that. been meaning to repaint my front lip andtake the car out to a couple random locations near me and get some proper pics too.
Postby M20_fever » Sun Jan 02, 2011 5:40 pm
post em' when you got em' ;)
Postby ten2doyle102 » Mon Jan 03, 2011 1:19 pm
I like that second to last one alot!
dmcl
Postby dmcl » Mon Jan 03, 2011 10:02 pm
ten2doyle102 wrote:I like that second to last one alot!
last pic has to be the most epic so far tho lol
drag racing a TVR cerberus. i stuck with him for about half of the 1/4 mile before he started walking. it was wet tho so neither of up got off the line too quickly.
Postby M20_fever » Mon Jan 03, 2011 11:17 pm
your NA right, no boost?
dmcl
Postby dmcl » Tue Jan 04, 2011 1:19 pm
yea.. stock low comp M20B25, UK/european car tho. stock exhaust doesnt have a cat and the car doesnt have a lambda sensor or the charcoal canister either. all the ones in the UK came like this as far as i know.
its actually a bit quicker than it was when those pics were taken, the dyno pics were before i started getting into tuning and the drag pic was with my MAF conversion and a not so great tune, plus i had a foam sock filter in the high beam hole and it kept sucking itself into the start of the intake lol, ended up putting 4 cable ties thru the edges and around the grill to stop it from sucking in at full throttle. cant wait to get the MAF conversion back on and set my new tune up to work with it, should be even quicker.
mods wise atm there isnt all that much, aftermarket coil, scorpion muffler on stock system, stock AFM with foam sock filter on the end, E36 325i 4 pintle injectors and had the TB bored out from the stock 60mm to 64mm. have a Z3 M coupe shifter in there as well as new stock engine mounts and poly trans mounts but thats about it..
