Sticky perogitive
Post your suggestions for our site
Sticky perogitive
Postby Yoshi » Fri Feb 27, 2009 2:31 pm
This is how it works guys. We aren't very technical yet because the forums are still blank. As long as the other forums are ok with it, you may copy over their info BUT you must cite WHO originally made the post and link to that post. I don't need IP lawsuits ;)
BlackMagic
Re: Sticky perogitive
Postby BlackMagic » Tue Mar 10, 2009 5:03 am
Swaybar Size List:
Eibach....................20mmF 16mmR
H&R........................22mmF 18mmR
Racing Dynamic........22mmF 16mmR
Ireland Engineering....22mmF 19mmR
318i(m10): Front: 18mm Rear: none
318is(m42): Front: 20mm Rear: 12mm
318ic(m42): Front: 21mm Rear: 12mm
325e(pre 9/86): Front: 18.5mm Rear: 12mm
325e(9/86): Front: 20mm Rear: 12mm
325i(m20): Front: 20mm Rear: 12mm
325is(m20): Front: 20mm Rear: 12mm
325ic(m20): Front: 21mm Rear: 12mm
325ix(M20): Front: 17mm Rear: 14.5mm
325ix Touring(M20): Front: 18mm Rear: 14.5mm
M3(s14): Front: 19mm Rear: 14.5mm
suspension techniques: front: 22 rear: 19
Whiteline 24mm front 16mm rear
AC Schnitzer: Front: 20mm Rear: 16mm
Eibach: Front: 20mm Rear: 16mm
Suspension Techniques: Front: 22mm Rear: 19mm
Ireland Engineering (adjustable): Front: 25mm Rear: 22mm
H&R (adjustable): Front: 22mm Rear: 18mm
Racing Dynamics Early Style (adjustable): Front: 22mm Rear: 16mm
Racing Dynamics Late Style (adjustable): Front: 22mm Rear: 19mm
M-Technik: Front: 20mm Rear: 14.5mm
Addco front swaybar, solid, 25.4mm, $182.95
Addco rear swaybar, solid, 19mm, $137.95
SummitRacing
(some may be repeated)
Author: BlackMagic
http://www.e30tech.com/forum/showthread.php?t=54391
It's not a question of how fast it will go, it is a matter of how fast do you want to go.
Postby Yoshi » Tue Mar 10, 2009 1:14 pm
you have to make a new thread. I think we already have a swaybar thread.
BlackMagic
Postby BlackMagic » Tue Mar 10, 2009 1:47 pm
Yeah I saw BUM BUM's thread after I made this.
