New wheels... What do you think?
Discussions about anything E30 related.
Mne666
Re: New wheels... What do you think?
Post by Mne666 » Fri Feb 07, 2014 6:49 am
Any pics?
Post by blasphemy101 » Fri Feb 07, 2014 5:26 pm
Keep in mind, you're going to need aftermarket elongated studs/bolts. A friend of mine just had a wheel come off on track due to aftermarket wheels/spacers and stock lugs...
Mne666
Post by Mne666 » Fri Feb 07, 2014 8:26 pm
I think if I do it I'll only use hubcentric spacers which should come with the bolts
Post by M20_fever » Sat Feb 08, 2014 5:00 am
Don't really have any good "stance" shots...
Post by Ryki » Sat Feb 08, 2014 1:24 pm
Such pretty cars, the both of you : ) I like the wheels, I think a slightly taller and wider tire with some good spacers and it'd perfect!
Post by 87e30 » Mon Feb 10, 2014 11:49 pm
M20_fever wrote: Image
Is it just me, or does it look like the 2 rightmost lugs are almost an inch further from each other than the left 2 are? Weird. That would be some funky bolt pattern.
Mne666
Post by Mne666 » Tue Feb 11, 2014 6:20 am
It does look like that , weird
Post by M20_fever » Wed Feb 12, 2014 2:56 am
Its custom 4x100x120
