My ever changing parts thread.
EricT
Post by EricT » Sun Jun 27, 2010 9:47 pm
PRICES ARE SHIPPED TO YOU DOOR UNLESS OTHERWISE STATED!!!! IF YOU COME PICK STUFF UP OF COURSE THAT WILL REFLECT ON THE PRICE!!!! MOST PRICES ARE ALSO OBO..... SO MAKE OFFERS.
For $150...I can mod your 24v harness so everything is plug n play in your e30.
Oil level, abs, c104 tach n econometer, auto delete....... I'll do it all... and it will work. Ship me your harness with your c101 connector, I'll do it up real pretty then I'll pay to ship it back. I normally have them back out the door heading to you within a week depending on how busy I am.
I also make 24v swap adapters with oil level sensors and can add c104 connectors. I have a couple ready to ship!!!! $75 shipped each
24v throttle cable brackets for on the throttle body..... $15 shipped each
24v alternator. Tested and it works great. $45 shipped
Rubber ebrake boot... no cracks and in wonderful shape.... $15 shipped
Metal water pump pulley for 24v engine...... $15 shipped
24v obd1 fuel rail with regulator........ $45 shipped
Set of nice m50 engine covers.....not seperating them $35 shipped
24v fuel rail with no regulator..... $30 shipped
Getrag 260 24vswap trans brace...... $85
M50 tps........ $15 shipped
eta sandblasted valve cover. $25 shipped
M50 plastic thermostat housing. No cracks. $15 shipped.
Set of pistons/ rods pulled from a vanos m50. $40 shipped
I also have a set of pop out windows with chrome trim. They are buried so I'll get you a pic if your interested. They are in good shape. $40 local pickup preferred
Drivers side visor with mirror.... not mint but very good condition.... $25 shipped
Headlight switch.... SOLD
Tweeters that work, pods with a broken tab on each.... $15 shipped
back of tweeters. They both have the same tit busted off the back.... but everything else is ok.
Brand new obd1 24v intake boot.... sold
New m20 "I" intake boot.... SOLD
L shaped or t shaped m20 "I" icv....$15 shipped each t shaped SOLD!!!
Brand new stock replacement subframe bushings....sold
M52 valve cover gasket set.... brand new still in original packaging...... $25 shipped
M42 flapper box with intake boot.... sold
M42 ecu....... $45 shipped
M20 cam gear.... $15 shipped
M20 damper pulley...... $25 shipped
complete set of lifters from an m50tu.... also used but in good shape........ $40 shipped
M20b25 injectors. Pulled from my m20 in place of some m50 injectors..... $35 shipped
A set of m50 4 hole injectors...... Need new caps and o-rings. Great cheap upgrade for your m20b25 $40 shipped
Delphin grey sunroof panel..... clear coat could be better........ the undersides clean tho. $50 shipped
Heres a little added protection for under your trans.... $35 shipped
Nice ZERO crack early model drivers side tail. $30 shipped
