FS - Fairfax VA 1990 325is S52 swapped (pix warning)
Postby Yoshi » Mon Jan 20, 2014 7:46 pm
Reluctantly putting this thing up for sale. It's a 1990 325is that is the most rust free E30 shell I've ever owned. I've put ~500 miles on the car since the swap. Holds temp great. The S52 is pushing around 240whp with the chip and port/polish job on the head. I can chirp tires in second gear by simply flooring it (no clutch futzing). Legally passed safety last week. The original build thread that I stopped updating is here: http://www.slidewaysonline.com/Forum4.0 ... f=8&t=1191
Asking $7k OBO
Factory options list and vin if you'd like to carfax it.
Goodies:
3 clutch 3.73 LSD
sold subframe bushings 12mm raised
xxr 513 15x8 et0
front tires 205/50/15 star spec direzzas (dunlop)
rear tires 195/50/15 kumho ecsta AST
TRM style eyeball CABS
Solid mounted B&M short shifter
Awesome generic head unit
Keyless entry
GC coilovers
M3 sway bar links
M3 harness covers (full)
Reading/map light
power sunroof
99% full tool kit
Swap:
S52
NV ported and polished head
OBD1 with RK tuning chip
S52 bottom
S52 cams/vanos
JB Racing flywhee/clutch kit
AKG swap motor mounts
ZF trans
E36 M3 DS
OBD2 headers modified to fit
Zionsville booster
Custom 2.5 inch exhaust
borla mufflers
High flow cat
M20 clutch fan
Mech coolant temp gauge
fuel pressure gauge inline
Replaced parts:
water pump
radiator
hoses
trans mounts (E30 OEM)
replacement rear calipers
replaced brake master
new clutch master
new clutch slave
E34 throttle cable
guibo
csb
Bad:
3/10 paint
washer stuck in spark plug hole
passed safety but pads/rotors aren't grabby
One fuel level sensor doesn't work
Odo stopped a while ago at 308
Re: FS - Fairfax VA 1990 325is S52 swapped (pix warning)
Postby M20_fever » Tue Jan 21, 2014 2:20 pm
a good buff and that paint would shine. GLWS.
Postby Yoshi » Tue Jan 21, 2014 2:57 pm
I'm not convinced it would. When it gets dirty, the grime gets sooo into the paint. I still want to give it a shot. Sadly, it's snowing. I washed this thing yesterday :)
Postby Nsquared97 » Sat Jan 25, 2014 6:10 pm
GLWS, that would be a riot.
Postby ten2doyle102 » Thu Feb 06, 2014 6:22 pm
ooooo......I would soooo buy that with my taxes... lol! Wives tend to get in the way of that though.... lol
GLWS!
Postby M20_fever » Fri Feb 07, 2014 2:00 am
What happened with the swap with Zach?
Postby blasphemy101 » Fri Feb 07, 2014 6:25 pm
Looks like a ton of fun. I'd drive the wheels off that lol
Postby Ryki » Tue Mar 11, 2014 11:36 am
If only I wasn't already looking at a E30 with crappy paint :P J/k, would be a great car if I wasn't hunting that M3 down. Good luck with the sale!
Postby Yoshi » Tue Mar 11, 2014 12:06 pm
Well that and you don't live anywhere near me currently lol.
Postby Ryki » Wed Mar 12, 2014 5:39 pm
Psh, one day I'll take leave and be coming through your way : )
Bridman225
Postby Bridman225 » Fri Apr 11, 2014 12:02 am
Hello Yoshi, any updates? If it's still available, Is it stable enough for a 6 hour drive and DD duties? I would love to have something like this... So conflicted.
Postby Yoshi » Fri Apr 11, 2014 12:08 am
I have a deposit on the car. You can convince the guy to give it up lol.
It should be fine to drive for 6 hours but with the under sized tires and super short diff, the highway is kinda... high rpm. Otherwise, it's a great car.
Bridman225
Postby Bridman225 » Fri Apr 11, 2014 2:39 am
Oh good'! If he or she buys it, I won't be tempted. What's the final price , if you don't mind me asking.?
Postby Yoshi » Fri Apr 11, 2014 11:44 am
haha that's between me and the buyer. But he talked me down and we took some parts off. So very affordable. You want the rims? lol
Postby Ryki » Fri Apr 11, 2014 4:51 pm
Good to hear you worked something out : )
