My bitch likes to drift... (videos)
EuroDrifter
Post by EuroDrifter » Fri Dec 31, 2010 3:38 pm
I can get pics if youre are interested ;)
Some videos are mid quality,sorry....
Hope you will enjoy it!
http://www.youtube.com/watch?v=l6D2T-MkUOM
http://www.youtube.com/watch?v=Dv6blDOiWI0
http://www.youtube.com/watch?v=MwjYvxXGHtw
there is more on my channel ;)
Re: My bitch likes to drift... (videos)
Post by Yoshi » Fri Dec 31, 2010 3:54 pm
I think I've seen those videos before. What's your car setup?
EuroDrifter
Post by EuroDrifter » Fri Dec 31, 2010 4:00 pm
yes,you saw them maybe @ E30Tech,what part of the setup interests you? a lots of mod's to write...
Post by Yoshi » Fri Dec 31, 2010 4:17 pm
mostly suspension/rim setup. spring rates, dampeners, tire sizes, sway bar setup, etc
EuroDrifter
Post by EuroDrifter » Fri Dec 31, 2010 4:46 pm
D2 coilovers with 10kg front springs and 9,8kg rear springs
Got few set of rims,8x17,9x17,8x16....
Tire sizes from 205.40r17 to 225/45r17 and 205/55 r16 (practice use only)
no sway bars :)
m20 turbo engine (eta bottom with 1bar,b25 head,schrick) with m50 gearbox and 3.73 welded diff,going to 3.45 in 2011.
Post by Yoshi » Fri Dec 31, 2010 4:53 pm
Why the lopsided spring rates? Every other E30 springs are higher rear than front.
Post by M20_fever » Fri Dec 31, 2010 9:15 pm
What size cam is the Schrick? Why did you ditch the G260?
Post by Yoshi » Fri Dec 31, 2010 10:46 pm
yea m50 gear boxes are weak.
EuroDrifter
Post by EuroDrifter » Sat Jan 01, 2011 10:26 pm
That was stock spring rates for drift coilovers...probably because of the engine weight in front...
Weak? Hm...i dont know for US m50 gearbox's but i didnt had any problem with it for last 3 years....
I took m50 gear box because of the better gear ratio...
Schrick is 284/272,stock springs...
Post by Yoshi » Sat Jan 01, 2011 10:36 pm
stock D2 rates doesn't mean it's right. If you look at every other spring kit for the E30, the rates are higher int he rear than in the front. It's like that for a reason.
US M50 gear boxes are Getrag 250s. They snap just over 300whp IIRC. You sure you don't mean the ZF 320D? The M3 trans? I had one of those but hated the gears because they were too short. Now I'm back to the getrag 260.
Post by M20_fever » Sat Jan 01, 2011 10:42 pm
What are the ratios for the Euro M50 boxes vs the US? Better final drive?
Nice driving, and an interesting paint scheme!
EuroDrifter
Post by EuroDrifter » Sat Jan 01, 2011 11:01 pm
5HP18 I dont know if there are diferences between euro and US gearbox's.
I got ZF laying in the garage but its a 5HP18,but got getrag 250 mounted on the car for 3 years...we also have few m50's turbo running stock gearbox...not a single problem.
I used getrag 250 and 3.73 at the rear,but now its a bit too "slow" for me,so i`m going to 3.45 diff for next season
Tnx ;) i`m painter but a lazy one lol,the sheme was never finished lol,but i`m going with another sheme for nest year ;) i`ll get the pics when done
EuroDrifter
Post by EuroDrifter » Sat Jan 01, 2011 11:06 pm
Well i dont have any problems with the spring ratios,since it has adjustable dampening and i had it nicely set for my driving style....When stiffer @ rear you easily loose grip at the rear,i dont like that...i rather like it sideways when i want that to happen :)
